wtd : 4.11 ratio open diff
Selling or wanted vehicles.
snork
Post by snork »
wanted : 4.11 ratio open rear diff to suit 95 surf
Apparantly its got a LSD in in now, which is no good as ive got a lockrite going in :?
muddy
Re: wtd : 4.11 ratio open diff
Post by muddy »
Is the front diff the same as the rear on the Surf like the Landcruiser? If so - put the LSD in the front and use the open diff from the front for the lockrite...
snork
Post by snork »
good idea....dont know thou.
Hopefully someone will tell me soon :)
rangimotors
Post by rangimotors »
nope, sorry buddy but ifs surf has a smaller front diff and it can't be swapped with the back.
I have an open diff i'd swap with your lsd but i think its the wrong ratio ill have a look on friday when im back.
I'm sure someone out there will have an open diff that they'd love to swap for an lsd (assuming they dont want to run a locker) they might even give you some cash depending on condition :D
snork
Post by snork »
well actually, i went off the code from the firewall, which said it was 4:11 open
Now im told its a lsd, so who knows what the ratio is now.
Its at the mechanics getting work done , so i will ask them to check ratio before reassembling
