abs problems on my 94 discovery
Posted: Sun Nov 21, 2010 7:34 am
by nova499
i have a 94 disco series1 face lift model and the abs light stays on
just wanderd if anyone has had the issue before and what are the common faults to make it a bit easyer to fix my problem.
Re: abs problems on my 94 discovery
Posted: Sun Nov 21, 2010 8:53 am
by chrome
yep my 94 did this, it cost me 90 bucks to reset it and then got a flat battery and hello its back again
i took the bulb out in the end
Posted: Sun Nov 21, 2010 8:56 am
by badnuz
it may be a split sensor wire or similar?
Posted: Sun Nov 21, 2010 8:05 pm
by nova499
cool thanks guys i will have a look after work tommrow and report back my findings
Posted: Sun Nov 21, 2010 8:50 pm
by Ralfie
Generally it will be one of the wheel sensors. You need to be able to either read the fault codes to determine which one or be able to test each one individually with a meter.
Usually the problem one is front left but not always.
I have found the sometimes removal and wipe clean and replace seating firmly will solve the problem for a while at least.
