Oil Light on 2LT
Theo
Oil Light on 2LT
Post by Theo »
I changed the oil and filter in my surf about a month ago but about 2 weeks after I did it my oil light came on and wont go off. I have checked the oil and its still full and the oil pressure gauge is showing a good reading, not to sure if the light is just stuffed or what.
Any help would be good!
mfrsr
Re: Oil Light on 2LT
Post by mfrsr »
have a look at the oil pressure sender, it's under the turbo from memory, maybe the plug/terminal has come loose and is resting on the block or the body? Check the wiring for damage/shorting.
