skid wrote:SirGerald wrote:skid wrote:have you thought about bolting a pintle hook there so you can have the best of both worlds, towing and snatching.
from what I've seen nobody has issues with them strength wise and I've seen some solid pulls off them
So are you pulling off the tow ball part??
yup, they are rated for snatching etc
cruiser is 2500kg and has snatched equally as heavy vehicles
its first ever test was 2 vehicles stropped together, so it works fine.
Combination pintles like that use a ball rated for both pulling at the lower curve and at the top. The rating isn't a breaking load like regular recovery points, they are rated at safe working load, often around 16,000lbs at the curve and 10,000lbs at the top.
Never use a tow ball for a recovery is popular advice, but you need to remember why its popular advice, then you'll understand why the combination pintle is safe for recoveries.
