JEEP WRANGLER GEARBOX BREATHER [AUTO ]
furnace
Post by furnace »
Is there any easy way to do this without having to take out the box ...Cheers
bernie
Re: JEEP WRANGLER GEARBOX BREATHER [AUTO ]
Post by bernie »
if it's a TF999 then the short answer is no. The std breather is in the oil pump housing and will have to be plugged. To do this, the torque converter has to come out and the oil pump out, then you got to drill and tap for the new breather, usually on top of the case somewhere.
Bernie
furnace
Post by furnace »
bernie wrote:if it's a TF999 then the short answer is no. The std breather is in the oil pump housing and will have to be plugged. To do this, the torque converter has to come out and the oil pump out, then you got to drill and tap for the new breather, usually on top of the case somewhere.
Bernie
Its A 2002 Wrangler,not sure what the Auto is,have been told they breath into the bell housing
yeti
Bruiser
Post by yeti »
dont know if this link helps but here ya go anyways :wink:
http://www.jeepforum.com/forum/f9/tj-3- ... up-361704/
v8 tj...luvs the gas......
furnace
Post by furnace »
yeti wrote:dont know if this link helps but here ya go anyways :wink:
Thanks yeti,just what i was after,that explains it perfectly..will sort as soon as i get a bit of time
yeti
Bruiser
Post by yeti »
sounds like a pita ... but gotta be done from what i have heard ,,, good luck mate :wink:
furnace
Post by furnace »
yeti wrote:sounds like a pita ... but gotta be done from what i have heard ,,, good luck mate :wink:
Thanks,probably do after xmas now,have been doing a bit of river 4x4ing on the Coast but nothing over the bonnet ..lol..all ok so far
Isuzu MU
Post by Isuzu MU »
furnace
Post by furnace »
Great stuff,thanks,have got a auto trans guy in Nelson that has done a few so will gret him to do mine i think
Return to “Jeep”
