Springs over diff - completed 4 Rugger!
For all Daihatsu related topics.
tuk
Post by tuk »
Hey
Just completed the front springs over diff on my rugger, pretty straight foward with no major issues. I only have a mud truck so geting a warrant wasnt a issue. I read some negative stuff about doing it to ruggers but for what im doing wif my truck itl be perfect. Minor fabrication for brackets was as technical as it got.
If anyone going to attempt it il let u know whats involved
cher
mattax100
Re: Springs over diff - completed 4 Rugger!
Post by mattax100 »
hi do you stil have a template for perches?
tuk
Post by tuk »
If by perch you mean the bracket that the u bolts and shock bolts to then i just reversed them or turned them up the other way and put them on the other side - sounds dodgy but worked well, cant remeber but may have had to drill the holes a little bit larger. Only major issue was in the rear, i had to put the shock on a little angle but iv had no problems and its been like that for a year or 2. if you want some pics let me know and your email and il take some photos. also rember to lengthen the front drive shaft - i didnt and did a jump and the shaft poped out.
cher
mattax100
Post by mattax100 »
Hi and i was meaning the brackets for the diff and fotos would be a big help mattax100@gmail.com
tuk
Post by tuk »
yea no worries il take a couple of photos and email them to you, i cut the weld off the bracket with a grinder(bottom of diif) and knocked the bracket off and re-welded on the top. had to put a bolt in the middle of perch as a locator for the springs. cheers
Return to “Daihatsu”
