Td27 turbo injectors vs td27 na injectors
navara66
Post by navara66 »
I am putting a turbo kit off a 89 terrano on my 91 navara, are there any difference between the na injectors and the turbo injectors or are they the same.
sibainmud
Re: Td27 turbo injectors vs td27 na injectors
Post by sibainmud »
Yip :wink:
Lynx
Post by Lynx »
navara66 wrote:there any difference between the na injectors and the turbo injectors or are they the same.
sibainmud wrote:Yip :wink:
Might have to be a bit more specific :lol:
Cheers Daniel
navara66
Post by navara66 »
do the turbo injectors flow more fuel at full cycle?? or can i use the N/A injectors for a turbo application.Will I have any problems running the td27 N/A injectors.Note I am changing the fuel pump over.
Lynx
Post by Lynx »
Why dont you just change both other, keep the injectors with the pump.
Cheers Daniel
sibainmud
Post by sibainmud »
To my limited knowledge they are the same injectors and different pumps. Mine was non-turbo, fitted a turbo, big exhaust and turned up the non-turbo pump. it pulls like a schoolboy :twisted:
nizmo
Post by nizmo »
a fella i know ran n/a injectors on his turbo engine no problems,
aroma
Post by aroma »
the turbos also had a oil squirted under the piston's to keep cooler well think thats what they were for
Lynx
Post by Lynx »
Hasnt the TD27T pump got a boost compensator on it? If so, you'd benefit greatly from using it.
Cheers Daniel
DieselBoy
Post by DieselBoy »
You will find that the TD27t injectors are set to a higher burst pressure than the TD27.
Using the TD27t injectors will give you more power and a cleaner burn.
It will still have more power than its ever had before on the TD27 injectors though, just not to its full potential.
Same goes for the injector pump.
You can increase the fuel delivery by turning the fuel screw in half a turn, but it will always be smoky off boost and you'l struggle to keep your egts under control as a result. But it will still work ok. It'l smoke down low in the rev's and run out of fuel(and power) up top, but it will work.
Fit the TD27t pump which has a boost compensator aneroid which controls the fuel delivery in relation to manifold pressure and your egt's will be mint all the time, it won't be smoky all the time and you should get better top end power.
navara66
Post by navara66 »
I have the complete turbo setup but carn't see any info on the injectors in the td27 hand book. I will just change them over.
I have also made some blockoff plates for the emission control gear,and will block off the 14psi pop off valve
