Help
Before I spend a few hours under the car, has anybody had the same issues? On a run North over the weekend, the overdrive failed. I had no o/d all the way up to Russell. When driving around locally the next day, the speedo failed but o/d worked intermittently. On the run back o/d worked for the last hour of the drive as well as the speedo. I'm hoping it's a broken wire or a dirty connection but if not, what could I be looking at??
Paul
Flashing O/D Light and No Speedo
Re: Flashing O/D Light and No Speedo
What vehicle ?
Then we can help...
Then we can help...
Did you have no overdrive? or was it the O/D light flashing?
If it was a flashing light there is a good chance it is sensor failure somewhere and it is flashing a code at you.
Had this with my Prado 1KZJ-TE , Fixed the speedo cable and all OK
I had the instrument panel out and on replacing it the speedo cable was not properly clicked in .
kbushnz wrote:What vehicle ?
Then we can help...
Ooops.......Surf..KNZ130 3.0
rokhound wrote:Did you have no overdrive? or was it the O/D light flashing?
No o/d and the light was flashing once every second.
Hi Yah
Have a read of this...
http://autorepair.about.com/library/faqs/bl153g.htm
You have a fault in the system.
Could be several things.
But as your speedo was playing up also...
I would take a punt its the speed sensor / pickup or wiring in that part.
There are two... One in the gearbox and one in the dash (if it is a cable driven speedo)
The link above should help you.
Have fun and tell us all what you find.
Calvin
Calvin
No over drive can be an ECU fault...... capacitors dead or leaking & munted tracks on board.... a not uncommon thing.
Well, the sun came out and dried the problems away! All appears good, so it looks like I have water ingress somewhere........it was raining when all problems began and now the rain has stopped, so have the troubles.....................
Just a quick update. The car ran fine for a bit and then started with the same problem again. The difference this time was there was no flashing O/D light. Having checked everything through, I have found a fault with the ECU. I've opened it up and found one of the pcb's has burnt and some solder on a capacitor has a poor connection. I've cleaned the circuit with meth's and sorted the dry joint and so far....all is good.
I shall be looking for a 2nd hand ECU to put in temporarily and get this one properly repaired, as I believe the repair may only be short term....
