Flashing O/D Light and No Speedo
Posted: Wed Dec 22, 2010 5:54 am
by Sir Plug
Help
Before I spend a few hours under the car, has anybody had the same issues? On a run North over the weekend, the overdrive failed. I had no o/d all the way up to Russell. When driving around locally the next day, the speedo failed but o/d worked intermittently. On the run back o/d worked for the last hour of the drive as well as the speedo. I'm hoping it's a broken wire or a dirty connection but if not, what could I be looking at??
Paul
Re: Flashing O/D Light and No Speedo
Posted: Wed Dec 22, 2010 6:44 am
by kbushnz
What vehicle ?
Then we can help...
Posted: Wed Dec 22, 2010 6:52 am
by rokhound
Did you have no overdrive? or was it the O/D light flashing?
If it was a flashing light there is a good chance it is sensor failure somewhere and it is flashing a code at you.
Posted: Wed Dec 22, 2010 7:51 am
by oldblue
Had this with my Prado 1KZJ-TE , Fixed the speedo cable and all OK :D I had the instrument panel out and on replacing it the speedo cable was not properly clicked in .
Posted: Wed Dec 22, 2010 9:58 pm
by Sir Plug
kbushnz wrote:What vehicle ?
Then we can help...
Ooops.......Surf..KNZ130 3.0
Posted: Wed Dec 22, 2010 9:59 pm
by Sir Plug
rokhound wrote:Did you have no overdrive? or was it the O/D light flashing?
No o/d and the light was flashing once every second.
Posted: Thu Dec 23, 2010 7:03 am
by kbushnz
Hi Yah
Have a read of this...
http://autorepair.about.com/library/faqs/bl153g.htm
You have a fault in the system.
Could be several things.
But as your speedo was playing up also...
I would take a punt its the speed sensor / pickup or wiring in that part.
There are two... One in the gearbox and one in the dash (if it is a cable driven speedo)
The link above should help you.
Have fun and tell us all what you find.
Calvin
Posted: Thu Dec 23, 2010 7:08 am
by tallsam66
No over drive can be an ECU fault...... capacitors dead or leaking & munted tracks on board.... a not uncommon thing.
Posted: Fri Dec 24, 2010 8:42 pm
by Sir Plug
Well, the sun came out and dried the problems away! All appears good, so it looks like I have water ingress somewhere........it was raining when all problems began and now the rain has stopped, so have the troubles.....................
Posted: Tue Jan 25, 2011 7:30 pm
by Sir Plug
Just a quick update. The car ran fine for a bit and then started with the same problem again. The difference this time was there was no flashing O/D light. Having checked everything through, I have found a fault with the ECU. I've opened it up and found one of the pcb's has burnt and some solder on a capacitor has a poor connection. I've cleaned the circuit with meth's and sorted the dry joint and so far....all is good.
I shall be looking for a 2nd hand ECU to put in temporarily and get this one properly repaired, as I believe the repair may only be short term....
