selling the truck off as bits
vvega
Post by vvega »
selling the truck off in bits
some bits are
18" coilovers
electric locking front 8" diff 4.88 ratio
electric locking rear disc converted 9.5" diff 4.88 ratio .. both have had new bearings seals
rear is serup for 4 link triaglated .. arms all made etc new chromally rose joints
hydraulic superwinch .. brand new sungear and bushings .. just needs new freespool and bolts to finish
its the high speed one .. same as mudzillers
ln106 cab .. needs front welded back on .. but its mostly there
shortend deck .. needs finishing .. extra wide guards
coon springs .. etc
piles and piles of stuff
ive spent moon beams on all this getting the good bits for it and most of it in as new
will seperate ... there is a chassis but contact me if you wanna talk a deal
Kiwi4x4
vvega
Re: selling the truck off as bits
Post by vvega »
front diff is high pinion
Kiwi4x4
juz
Post by juz »
How much for 1uz? does it have uncut wiring loom,AFM etc? cheers
vvega
Post by vvega »
it has a v88 vipec ecu .. brand new in a box .. stock ecu is useless
its a 2002 1uz vvti engine .. done 30,000 km
full toyota gasket kit genuine
brand new waterpump .. still in box
AND a external craig davies pump (alloy housing) with digital controller .. thats worth about a grand buy itself
these make the same power as the 3uz's 4.3l over 300 hp on aftermarket efi
its a fairly extensive setup
cost me over $7000 to acumulate
2500 for engine
3000 for ecu + 200 for 5 meter loom A
200 for 7 bar map sensor
500 for gasket set
1000 for electric waterpump
some other figures
rear transfer cost me 1000 to acquire and then rebuild
not inc the cost of the auto rebuild and customisation
the motors in the lockers have been rewound
both front and rear diffs rebuilt with new bearings shims etc
the bearing kits for them alone are 300 bucks
this is gear for someone wanting a good solid buy . you wont have to rebuild it when you get it it like i had to
same with the winch .. most parts have been replaced with parts from traxuis nz
750 worth of rebuild parts at 30% off + a brand new motor
the rose joints in the arms are sk teflon cromally jobs 3/4 inch
oh and a high steer kit as well
probably suits someone who wants to build something exceptional
and wants to save on the parts required to do so
Kiwi4x4
T-Boon
Post by T-Boon »
I`m kinda curious why the V88? for the VCT controll?
Will it work fine without the electric water pump ? (aka standard config)
How many k`s on the engine?
And photo`s ?
To Boon or not to Boon.
vvega
Post by vvega »
v88 = flyby wire and proper peak and hold injector control and vvti control
yes you dont need the davies water pump .. there is a brand new genuine one in a box there for it
along with the complete gasket kit
30,000km on the motor
and no pictures atm .. its in storage
oh thats right your nicks brother .. face book me dude
Kiwi4x4
dawwen
Post by dawwen »
How much for the coilovers?? How much for the whole project as it sits??
vvega
Post by vvega »
there is about 25k worth of bits there
coil overs ... hmm 2 k
Kiwi4x4
andrew007
Post by andrew007 »
hi m8, hell of a shame you couldn't finish it & drive for awhile. :? have got a new project on the go? :roll:
cheers andy
vvega
Post by vvega »
nah no projects for a bit . need to focus on life a bit more atm
give me 5 years and ill do a jeep with atlas bits under it
but for now it might be time to buy a house
Kiwi4x4
SMOKEY
Post by SMOKEY »
Hi vvega, sorry to read you are not going through with this project, buying a house and five years before your next project sounds like nesting to me :lol: :lol: , has something better come along :roll: :roll: , ----- what ever I wish you all the best.
Being an old style mechanic who hasn't kept up with modern technology I was always interested in your posts and builds. If you have time I would be interested in your working background you are on top of the modern requirements for the building and running of the new breed of motorsport and it's Techno's like you who are equally proficient with a Laptop and a spanner that will take motorsport into the future. Wishing you well and
DON'T BE A STRANGER TO ORE,
FITZY.
flyingbrick
Post by flyingbrick »
omg vvega must have met someone special. :mrgreen:
flyingbrick
ps, didn't you have a viair (or something) air compressor sitting around wayne? the sort used to fill tanks on an air-bagged car usually.
vvega
Post by vvega »
SMOKEY wrote:Hi vvega, sorry to read you are not going through with this project, buying a house and five years before your next project sounds like nesting to me :lol: :lol: , has something better come along :roll: :roll: , ----- what ever I wish you all the best.
FITZY.
hey fitzy .. yeah unsure ex what im doing .. considering going back to uni and studing law even .... nothing in the local job market unless i wanna go out for myself .. and im not sure i wanna do that just yet. considered moving to aucks .. or back to chch for jobs atm but well have to see what happens
just glad to be moving on
Kiwi4x4
smiddy
Post by smiddy »
I hear you might have a supercharger setup that you may be selling also?? manifolds etc?
vvega
Post by vvega »
gone .. as is the turbo's
was gunna twincharge
Kiwi4x4
Sleepn
Post by Sleepn »
Have you got any pics or model numbers for the coil overs so I can check them out? Cheers
jeremy
Post by jeremy »
Sleepn wrote:Have you got any pics or model numbers for the coil overs so I can check them out? Cheers
18" FOA's I believe...
http://www.offroadexpress.co.nz/Forums/viewtopic.php?p=223393#p223393
vvega
Post by vvega »
http://www.trademe.co.nz/Browse/Listing.aspx?id=414179925
http://www.trademe.co.nz/Browse/Listing.aspx?id=414180788
http://www.trademe.co.nz/Browse/Listing.aspx?id=414182713
there is also a chassiy 70% modded to take all this gear
and a cab ... and a tray and a hydralic superwinch .. and im sure some more crap
if you have 5 grand and want a pile of bit's to build something awesome .. you have have the unlisted shit for free ....
Ive paid out over 10g cash for everything left ... so 5g is a steel
ATM its doing nothing and its wasting away
021 873 177 if your genuinely interested and have a proper cash offer
Kiwi4x4
vvega
Post by vvega »
front diff is now gone ... signed sealed and picked up
Kiwi4x4
MNC
Post by MNC »
Damn, I wish I could afford those shocks... AWESOME!!!!
Sorry to hear you are getting out of it dude. You are a Lexus genius :!:
