wiill a td42
ALS4B
wiill a td42
Post by ALS4B »
will a turbo of a sd33t g160 bolt up to a td42 after more power for towing at mo are running 3'' pipe
Crash bandicoot
Re: wiill a td42
Post by Crash bandicoot »
ALS4B
Re: wiill a td42
Post by ALS4B »
doesn't realy show if it will bolt up. I have herd of it been done i might have wrong motor numbers not sure can anyone help
Crash bandicoot
Re: wiill a td42
this should answer your question
http://www.patrol4x4.com/forum/general- ... pecs-1107/
Originally Posted by Storm
As far as I can find the Patrol came with this turbo:
Garrett Nissan Patrol TD160/GR-Y60 1983- SD33T
(3.3) 110 D - HT15B 14201-C8700 3K
This comes from other company:
Turbolader Nummer: 1047061
Marke: HITASHI
Typ: HT15
TURBOLADER HT15-48B
OE Nummer: 14201.C8700
OE Nummer: 14201C8700
ALS4B
Re: wiill a td42
Post by ALS4B »
Have found the truck with this set up on and is a sd33t turbo on a td42 manifold look real easy to do . K I S S .
