reverse lights
Posted: Sun Jan 02, 2011 2:10 pm
by 89lux
hi guys
where is the reverse light swith on the box of a manual ln61
Re: reverse lights
Posted: Sun Jan 02, 2011 2:42 pm
by Crash bandicoot
Re: reverse lights
Posted: Sun Jan 02, 2011 4:50 pm
by 89lux
im not sure how to post pics but basically i have 4 cut wires and 2 sensors with cut wires
one sensor has 2 black wires
the other has a black and a pink
the cut wires- one pair is red/white stripe and red
other pair is green/yellow stripe and white/black stripe
Re: reverse lights
Posted: Sun Jan 02, 2011 7:20 pm
by 89lux
bump
Re: reverse lights
Posted: Sun Jan 02, 2011 7:25 pm
by Crash bandicoot
this is trans code G52
the only two you'd need are for the 4wd engagement light on the dash and the reverse lights. any others are nice to have, but not required
i have the manual and diagrams here for LN/RN and YN 30 to 130 and all the models diagrams are generic when it comes to the reverse lights.
switched/fused ignition from fuse box in engine bay to gearbox switch, into tail lights( and reversing buzzer for auto's) and then grounded.
accordingly the manual says the wire from on the 30/40 was colour code RW to from the power feed to the switch, then RL from the switch in the gearbox to the reverse lights, then WB(white/black) from the lights to ground.
later models the power feed to switch is red then red/black from switch to lights.
some one may be able to help out with the colours, as this is all in black and white
Re: reverse lights
Posted: Sun Jan 02, 2011 7:42 pm
by Crash bandicoot
in saying that, none of them are a Wof issue anyway.
Re: reverse lights
Posted: Sun Jan 02, 2011 9:32 pm
by 89lux
thanks heaps mate after reading that i had it fixed in 5mins
