Front Lokka
Posted: Mon Jan 03, 2011 10:35 am
by contour
was out the other weekend and thrashed the old girl to much.
and blew a cv to bits. now the front lokka isnt working. and a clicking noise when turning.
can see the drivers tyre shudder when clicking starts.
and its a brand new cv
Re: Front Lokka
Posted: Mon Jan 03, 2011 5:18 pm
by taz01
check the lokka pins and spider gear pin maybe chipped the pinion gear i destroyed all of them but cv was sweet...........
Re: Front Lokka
Posted: Tue Jan 04, 2011 1:12 pm
by contour
Cheers taz might have to get a new lokka.
Re: Front Lokka
Posted: Tue Jan 04, 2011 1:23 pm
by taz01
lokka maybe still be good its the surrounding bits that are weaker the 4 lokka pins are designed to shear off 50bucks a set of pins and springs
Re: Front Lokka
Posted: Mon Jan 10, 2011 6:17 pm
by contour
found the problem now got to find new one
Re: Front Lokka
Posted: Mon Jan 10, 2011 7:08 pm
by Muzza
Man ! :shock:
those cross pins are solid. I'me surprised that broke.
The 4 small pins in my LOKKA shore off when I broke a front hub.
4WD systems and our NZ importer will tell you that the pins will only shear off if the setup clearances are out of spec
BUT .... :?
my diff is MINT with no wear and all clearances are bang on their spec's and they still shore of.
Anyone else had their pins break even though the diff clearances were within spec
Re: Front Lokka
Posted: Mon Jan 10, 2011 7:25 pm
by IcedJohnno
Muzza
You say your diff has no wear and the clearances are how they should be.
The clearances have nothing to do with the CW & P. It is the diff carrier side clearances that are the issue and these are not necessarily correct for a lokka even when not worn.
Check out my post here; http://www.offroadexpress.co.nz/Forums/ ... 22&t=23605
It gives the correct clearances and how to measure them.
Re: Front Lokka
Posted: Mon Jan 10, 2011 7:27 pm
by taz01
only broke once ........note mine in 4 spat one chunk between the lokka and the housing actually dented the housing but lokka sweet
check the pinion gear and lokka pins before getting carried away putting together
Re: Front Lokka
Posted: Mon Jan 10, 2011 7:43 pm
by contour
yea the pinion gear has a bit of damage but is fine to use just a bit of rounding.
Lokka looks fine
Re: Front Lokka
Posted: Mon Jan 10, 2011 9:43 pm
by Fakey
Did you find a new pinnion shaft?
Re: Front Lokka
Posted: Tue Jan 11, 2011 8:45 am
by contour
nope tried nissan none in country.
its the spider gear pin.
Has anyone got one floating around
Re: Front Lokka
Posted: Tue Jan 11, 2011 4:33 pm
by taz01
for the cost of a pin from nissan get a diff head off tardme.
Re: Front Lokka
Posted: Tue Jan 11, 2011 5:45 pm
by contour
got a new pin of nissan $59.
Re: Front Lokka
Posted: Thu Jan 13, 2011 8:59 pm
by Fakey
I put a 4 pinnion lsd terrano centre in my front diff so ive got a spare centre sitting here :wink:
