air supension compressor
Posted: Mon Jan 03, 2011 2:08 pm
by red-devil
i know i own a toyota, but
i under stand the land rover mk 3 has a compressor that run the air shocks at 200 psi when set to road.
i,ve been told they will work good as a compressor just need a tank.
well were would one find a good second hand unit.
close to chch would be grat but now that i've seen one ill ship it.
jono
Re: air supension compressor
Posted: Mon Jan 03, 2011 6:09 pm
by tallsam66
As its only used for suspension i doubt it would flow a very high volume of air.... would be prudent to check this out before getting one.
Posted: Mon Jan 03, 2011 7:31 pm
by red-devil
has a flow rate of about 0.96 cfm at low pressure, and according to justcompressor.com it can fill a 3 gallon tank from 0 to 150 psi in 4 minutes 45 seconds.
It is commonly used by low rider fans to pump up their vehicles. It has to keep the 10 liter (2.5 gallon)
Range Rover air tank charged up to 10 bar (150 psi),
which is a much higher pressure than most off-road air compressers can reach. The compressor also has a much harder life than the average air compressor, having to operate in hot under-the-hood conditions (it is rated at 158 degrees ambient) for hundreds of hours rather than a few minutes at a time
Posted: Mon Jan 03, 2011 8:19 pm
by nstacey
You might want to check what model you need the compressor from as there is no 'mk3' model. A series 3 definitely doesn't have air suspension but a Discovery 3 does... I don't think there is a particular Range Rover model '3' but air suspension was at least an option from around 92 in the classics. You are probably more likely to find one from a P38 which is a 94 onwards. I couldn't tell you if one would meet those specs in your post, will see if Dad has a book on them...
Posted: Mon Jan 03, 2011 8:51 pm
by 91Rangie
nstacey wrote:You might want to check what model you need the compressor from as there is no 'mk3' model. ...
The L322 Range Rover is also know as the MK3
Theres one being parted out in Christchurch on tm here
But judging by his prices he will want a bit for it
Posted: Mon Jan 03, 2011 9:31 pm
by red-devil
been reading up a little more you'r correct it is out of a p38.
those are the specs of the pumps after a rebuild.
im just looking to see look to see if i will work, a its small enuff to fit in the rear quarter.
will be great if you can find more info
jono
Posted: Mon Jan 17, 2011 6:45 pm
by Gofer
Works like a charm, got one connected to a mobile tyre inflation tank strapped in the back of mine just fior the truck horns..............
Posted: Mon Jan 17, 2011 8:28 pm
by red-devil
were abouts did you fget one from. its a little hard to locate them here in chch
Posted: Thu Jan 20, 2011 6:52 am
by Gofer
Try Stag 4X4 in West Auckland. They had some but not sure how their stock changes. Speak to Martin.
Posted: Sun Apr 03, 2011 5:27 pm
by Disco Gofer
red-devil wrote:been reading up a little more you'r correct it is out of a p38.
jono
My recon Rangie pumpis inside behind the right rear trim panel and the tank sits out side strapped to the where the dickie seat normaly goes. From there i have plumbed the Disco right through for the truck horns, pumping tyres etc, I can give you my olf frined's name as we used to work for Land Rover and he still does a bit of mobile work and lives in Marshlands. He has a few lying around in various states of repair but can get the kits from the US quite cheap and has one in stock too when i was there 2 weeks ago.
Posted: Sun Apr 03, 2011 9:52 pm
by red-devil
Disco Gofer you've got PM
