Longer front driveshaft
Ive just moved my Hilux diff forward by 35 mm.When i get it to full artic the shaft separates. With the lift and diff move i think it needs to be 50mm longer.Is there a longer factory one or do i get it lengthened
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Re: Longer front driveshaft
Lengthen it bud
There is a bogan fix that involves a spacer between the UJ's, but I would make it longer.
When you measure up the new length, make sure you have room for the slip joint to compress with out punching up the pinion.
There is no way in hell i would space it .I was hoping maybe i could get a longer factory one . If lengthening it is the only way then thats it .I tried circle track today but are they still closed
Because it is a front one, I don't reckon there is a great need for it to be done full on (Ie tom could sort it for you), unless of course you do high speed's in 4wd.
Your call.
Your call.
I didnt even think of tom. cheers . Is dave still working with you
Check the outerlimits hilux bible. there is a thread there on the fromt shafts. From memory the later IFS ones were the longest. There are three lenghts I think and the longer 2 have better double cardons (total movement).
The DC's on IFS surf's typically have much less movement, although they can be clearanced to make them work (just easier to use a solid axle unit).
Shaft is at toms place . As we speak
