im after parts for my defender 90 1998 im after the steering drag arms front and rear of the front diff also a side panel on passenger side that the rear sliding windows are in, (the panel between the wellside and the roof
any help of local or aus or uk with websites or companies you know of or private people would be great
thanks ben
defender 90 parts wanted 1998
Re: defender 90 parts wanted 1998
Would spares dfrom South Africa be ok? i have a few contacts from my mechanic landy days in Durban that i could dig up and get the conact details to you.
sorry to hijack your thread but does anyone have an e-mail address for Landroverspares.co.nz?
1988 Range Rover Classic
2010 Discovery 4 HSE 5.0 V8
Landy world
- Newbie
Hi, try canterburylandrover.co.nz
A discovery tie rod (behind axle will fit), you may want to cut the damper bracket off it, but don't have to (Disco/rangie damper is behind axle - Defender damper is up under front crossmember)
The drag link in front is not a straight swap afaik and will need to be a Defender item.
Canterbury Landrover on Hazeldene Rd are good guys to deal with.
Where abouts are you?
Wouldn't happen to be a slightly accident damaged white 50th anniversary V8 90 would it??
