lj78 cruiser
rob-mu
lj78 cruiser
Post by rob-mu »
Want to get some new springs and shocks for my lj78 prado
I understand Aussie never sore this truck but still thought OME did springs for it.But according to peter munroe they don't. I was going to get efs but just got a qoute from 4wdbits and the prices have increased over $200 from a few months back :(
Rob
haynzy
Re: lj78 cruiser
Post by haynzy »
badnuz at arb has looked in to this for me and they can do springs for them, also king springs do them but only like 3in lift I think
rob-mu
Re: lj78 cruiser
Post by rob-mu »
Cheers for that info.I don't want much of a lift 50mm max
rob
ClassicCruiserSpares
Re: lj78 cruiser
Why dont you go and talk to Mark at Chamberlians he should be able to sort something.
rob-mu
Re: lj78 cruiser
Post by rob-mu »
That could be a option
rob
mudmike
Re: lj78 cruiser
Post by mudmike »
can also get an EFS 50mm lift, talk to traxon. one of the guys there has an lj with an exo and lexus swap. I'm running the EFS kit and very happy.
Good luck
kbushnz
Re: lj78 cruiser
Post by kbushnz »
mudmike wrote:can also get an EFS 50mm lift,. I'm running the EFS kit and very happy.
Good luck
Hey Mike
Can you do me a favour and measure the distance between your axles and bump stops, front a rear.
Interested in comparing to my custom springs in my KZJ78. They have drooped over the past few years and was thinking about the set at Traxxion.
Calvin
axel
Re: lj78 cruiser
Post by axel »
wjw
Re: lj78 cruiser
Post by wjw »
Good luck
Hey Mike
Calvin
I had Chamberlains springs in my KZJ78 and they never sagged.
rob-mu, rick @ 4wdaccessories is the traxion dealer for Christchurch 03 3651909 he also has ironman stuff too
Who knew Prados could fly?
howieh
Re: lj78 cruiser
Post by howieh »
Have heard but (not tried) that 80 Series fit and give a 50 mm lift.
I have a LJ78
juz
Re: lj78 cruiser
Post by juz »
Ive found the same trying to get springs for my LJ71, Ive put 80series springs in in the mean time but there very hard riding I think the correct spring rate for the size of the truck would be better. You need two pairs of front 80series springs to do it to a 71.
rob-mu
Re: lj78 cruiser
Post by rob-mu »
Ok still weighing my options as I'm still not 100% if the OME FRONT springs fit. some say they do,some say they don't.for anyone that might be interested
EFS part numbers:
Front shock - 36-5553
Front coils -
TLC-104E - up to 60kg of accessories
TLC-104HDE - 60 - 100kg of accessories
Rear shock - 36-5554
Rear Coils -
TLC-114E - Constant 100kg
TLC-114HDE - constant 200kg
OME numbers:
front: 2874 springs, N77 shocks
rear: 2875 springs,N79 shocks
haynzy
Re: lj78 cruiser
Post by haynzy »
rob-mu wrote:Ok still weighing my options as I'm still not 100% if the OME FRONT springs fit. some say they do,some say they don't.for anyone that might be interested
EFS part numbers:
Front coils -
Rear Coils -
OME numbers:
how much for the efs ones?
kbushnz
Re: lj78 cruiser
Post by kbushnz »
I ran the OME coils and shocks when I first did mine.
Going thru my files I used...
OME 874 (HD) and N77 for front.
OME 873 (MED) and N79 for rear.
They worked fine....But I found them a little stiff and then went for the Chaimberlains setup
CTFR-116SP and CTRR-240SP...
They sagged and I felt were too soft as they were speced on the original coil rates...And for the type of driving I was doing.
.(I know the guy who had them first made up)
Here is some info on those OME coils
I think the HD I used in the front as these coils were designed for the LJ70 and the 2.4 is lighter than the 1KZTE...
But in my case I had barwork in the front.
It worked out fine.
________ wire_N/mm_turns_Height___info__________________
Rear
OME 873 17 35 10 455 +40mm 50-110kg Medium
OME 875 18 42 10 440 +40mm const 100kg HEAVY
Front
OME 872 14 33 9 400 +30mm Medium
OME 874 15 38,5 9 408 +30mm 51-110kg HEAVY
standard springs have 13mm wire front and 15,5mm rear
I run currently 80 series front coils in the rear and they give a big lift.
I had custom coils made at Chamberlains in Chch but they have sagged 60mm......
Shocks were Toughdog in the rear and speced from a Landrover....
I am going to drop mine soon to the EFS 50mm lift setup as now running 35's and have height via tyres.
Have fun
Calvin
rob-mu
Re: lj78 cruiser
Post by rob-mu »
for EFS Thru 4wdbits they were $180 per shock and $262 a pair for springs
4wd acc was a bit more pricey
but the latest qoute from 4wdbits is shocks $225 and $300 a pair for springs
Rob
rob-mu
Re: lj78 cruiser
Post by rob-mu »
looks like I will be going to get the EFS setup from 4wdbits as they will do the shocks for $180 and springs $300 a pair
I talked to a bloke from Traxion
$225 shocks
$339.25 a pair for springs
Note: FYI I believe the rating of 60kg listed is a little bit high for the TLC-104E although I realise it is in our literature it should really be closer to 15-20 kg accessories for 40-80 kg I would look at the TLC-104HDE which are the same price
gimmemud
Re: lj78 cruiser
Post by gimmemud »
If your looking at aussie gear they were called a bundera over there and only came in short wheel base
mudmike
Re: lj78 cruiser
Post by mudmike »
No don't look at bundera gear, they had a very strange rear axle set up, one shock in front of diff and one behind, and the springs are different on both sides. looked at a kit some years ago.
jeremy
Re: lj78 cruiser
Post by jeremy »
...and the front spring & shock setup is completely different in those earlier models as well
Re: lj78 cruiser
look at ome shocks and king springs .... my old lj71 (92) had these .... the ome springs are too high/bouncy apparantly. current lj71 (89) which is the earlier "bundy" has the same setup. the suspension setup looks the same as the later ones apart from the earlier trailing? arms on the diffs. no rear steering shock ? the front looks the same, arms and panhard measured the same between 71 & 78
DEAN40
Stropper
Re: lj78 cruiser
Post by DEAN40 »
If you haven't already sorted it out, call Phil at Traxion and he will allways cut a good deal. I've got his efs shocks and springs all round. Fantastic... Much cheaper than 4wd bitzzz
