its a xj
where is the temp sender?
got radiator isues and cant find the the temp sender
its a xj
its a xj
Re: where is the temp sender?
fish wrote:got radiator isues and cant find the the temp sender![]()
its a xj
On the 4lt the Temp sensor that talks to the ECU is on the thermostat housing and the Temp sender for the water temp gauge is towards the rear of the engine closer to the firewall.
yep i tested my fan by jumping it to the battery and its fine, my gage works but not the electric fan so it must be the temp sensor
repco cant get any, you got any ideas where i could find one?
have a look in here ,,might help ya ..... http://www.offroadspecialties.co.nz/catalog/36
v8 tj...luvs the gas......
Check out ebay.com, probably cheaper than buying over here, failing that I have one from my old XJ that worked fine when I parted it out, if you want it, just pay for postage.
JK Wrangler 35s.
