Surf horn not working, not fuses.
T-Boon
Post by T-Boon »
Do they have relays ?
To Boon or not to Boon.
UBZ
Re: Surf hron not working, not fuses.
Post by UBZ »
They run in a series setup , if the passenger side horn is blown the drivers side won't work.
I chased tail on mine for weeks untill I plugged an after market air horn on to the passenger side and away it went.
T-Boon
Re: Surf horn not working, not fuses.
Post by T-Boon »
Ha, didnt even know there were two, will have to have a look this weekend.
Its never worked since I swapped the steering column...
bruntonjm
Post by bruntonjm »
check the contacts on horn button. they can clog up with carbon etc....
T-Boon
Post by T-Boon »
Checked all contacts and plugs, have plugged and unplugged several times to free em up ..
MikeL200
Gadget Guy
Post by MikeL200 »
Check that it is earthed properly.
Mike
1989 LandCruiser MWD BJ74 13BT
33 Deserthawk XMT.
If guns kill people, then,
Spoons make people fat,
Pencils mis-spell words,
and Cars make people drive drunk.
021 666812
bruntonjm
Post by bruntonjm »
try using a volt meter and trace it back through...
Lynx
Post by Lynx »
smash the crap outta the horn with a hammer, the usually jam up.
UBZ
Post by UBZ »
Thier is a relay up under the dash somewhere, will have alook at the fsm later and let you know the location.
When you press the horn you should get 12v at the horn plug. And be able to hear the relay clicking under the dash.
12v can be directly conected to the horn to check if It is blown or jammed up
I would be closely inspecting the column though as the horn stopped after you played with It
dazza85
Post by dazza85 »
UBZ wrote:I would be closely inspecting the column though as the horn stopped after you played with It
What he said ... If it worked fine until you did work on the column and then it stopped that will be where your problem will be.
It is very unlikely that the relay or the horns will have suddenly failed at the same time as you did work on the column.
most horn switches are a single wire that is earthed when the button is pressed. trace the horn wire on the column and earth it and the horn should work ( some require the key to be on ) As "bruntonjm" the actual switch contact carbons up, or wears down so it does not touch at all.
Return to “Tool Shed”
