Rims
For all Isuzu related topics
brianr70
Rims
Post by brianr70 »
Are 6 stud rims, say off a Hilux interchangeable with other 6 stud makes like Isuzu?
for example:
http://www.trademe.co.nz/Browse/Listing ... =348696772
I travelled the road less travelled now where the heck am I!!!
4WDbits
Re: Rims
Post by 4WDbits »
Usually. There are a few 6/139.7 PCD steel rims with a centre of 108mm which means they don't fit Nissans. Most 6/139.7 PCD have a 110mm centre bore. Not sure what is required for the Isuzus.
mud_slinger
Re: Rims
Post by mud_slinger »
i have surf rims on mine
needs more curry
0272593533
dazza85
Re: Rims
Post by dazza85 »
did you find some ??? I have a set that are in average condition that need a new home at a very affordable price :wink:
FORGE1
Re: Rims
Post by FORGE1 »
I have 15x8 or 8.5 (cant remember) alloy rims that were on my Safari and bolted straight on.
Im running 32x11.5 Mud Stars and rub on full flex. I have LWB springs in the back and wound up the front.
Mattman
Re: Rims
Post by Mattman »
What sort of 32's do you have? I am about to fit an OME lift kit and 33in Maxxis Bighorns which measure at 32in.
Am hoping for minimal rubbage....
Re: Rims
4WDbits wrote:Usually. There are a few 6/139.7 PCD steel rims with a centre of 108mm which means they don't fit Nissans. Most 6/139.7 PCD have a 110mm centre bore. Not sure what is required for the Isuzus.
this is correct
for what brianr70 is doing it should be fine, but if you were going the other way you will find that Isuzu rims have the smaller centrebore
bought some 15 x 6" bighorn steels once to widen etc and found they had the smaller centrebore
Drurban
Re: Rims
Post by Drurban »
My friend is using my old rims, and he has a Toyota Hilux and I have a Isuzu Mu.
Ruben
FORGE1
Re: Rims
Post by FORGE1 »
Mattman wrote:What sort of 32's do you have? I am about to fit an OME lift kit and 33in Maxxis Bighorns which measure at 32in.
Im running Nankang Mudstars they are a smaller sized 32inch tyre I only get rubbing at full lock and reversing. There is a guy in town that has a maxitrac lift in his with Bridgestone Dueller M/T and they are 33x12.5x15 with small rubbage as well and they are a bigger 33inch size tyre so you should be all good.
Return to “Isuzu”
