I have 2 mint 33x9.5r15 bfg mt and 2 worn tyres but no one makes this size any more.
can i run 33x10.5 on the rear and move the 9.5 to the front or just get a whole new set.I dont realy have $1000 plus to spend on tyres any ideas.
problems finding 33x9.5r15 what to do
- mud_slinger
Re: problems finding 33x9.5r15 what to do
you want all tyres the same size, when in 4wd may put stess on the drive train and break something
needs more curry
0272593533
0272593533
I wouldn't have thought different widths would be a problem, is it full time or part time 4wd?
Who knew Prados could fly?
Wider tyres on the same sized rim would bulge slightly bigger than the narrower tyre I'd have thought.
They are on a d21 navara double cab part time 4wd.The tyres are on 8 inch steel wheels.
As long as rolling diameter is the same on the axle (side to side), width shouldn't matter a fark (as long as they will run on the truckl).
A 285/85 16 is the same as a 33" tyre and I am guessing it would equate to a 9r, you could try and find a 285/85 15 tyre and try it I guess.
rokhound wrote:As long as rolling diameter is the same on the axle (side to side), width shouldn't matter a fark (as long as they will run on the truckl).
Providing its part time, which it is
same width side to side means equal work in the diff but different diam front to back means the driveline can fight against itself doesn't it?
I was in this boat 6 months ago
My zook came with different size tyres front to back an inch bigger and wider in the rear and i noticed on hard stuff the tyres would scrub a bit. I figured this wouldn't be good for things.
I just flicked the two and bought a full set. You could sell one and keep the other as a spare?? Could you run a different brand/model tyre as a pair of the dimensions you want??
BFG were the only place that made a 33x9.5 and they don't even list that size any more. I rang around alot of places in hamilton with no luck.I like the size but don't want to spend 2k on new tyres and if i go any wider they will stick way out of the guards in the front.
