LN130 4WD Problem
nt_a_foz
LN130 4WD Problem
Post by nt_a_foz »
Looking at a 2nd surf a LN130 as my 3.0L one to tidy to bush bash.
The one im looking at has a issue with the 4x4 system. The guys a mechanic and reckons the hubs and gearbox are enganging but something in between is not.Seem to think its a electrical problem..
Any one have any ideas? Is it a common problem or easy potentially to fix?
Im keen to get it as body is ruff perfect for hacking but the motor is mint and been rebuilt.
Filthy4x4
Re: LN130 4WD Problem
Post by Filthy4x4 »
My 4wd system stop working on me in my ln130 the other day. The light wouldnt come up on the dash and if i was slowly rolling and engaged 4wd it would just beep at me. Turned out to be a loose plug on the transfer case.
Might be worth checking?
027 MUD GEAR - (027 683 4327)
Check our facebook:
Crash bandicoot
Post by Crash bandicoot »
mine did this, turned out to be a sheared inner axle on the front diff.
UBZ
Post by UBZ »
Have you jacked up the front And checked 4wd is actually engaging ?
If it is , you have an electrical issue , if not I would look at the vacuum lines / system first.
No 4wd light on the dash and beeping means one of the 4wd indicator switchs is not engaged and/or working
Or that the front diff is over heatIng
Front diff the indIcaror switch is on the back of the diff, this circuit must be closed for the 4wd light to come on .
On the front of the diff is a temp sensor switch , if this circuit is closed / shorted no 4wd light and beeping.
On the the transfer case , one plug for the solenoid , the other is the 4wd switch, this circuit must be closed for the 4wd light to come on .
Apart from that , it could be the 4wd computer or wiring harness.
nt_a_foz
Post by nt_a_foz »
Beauty thanks for that UBZ, i think im going to get it anyways and ill just tinker till i find the problem. That information looks like itl be handy.
Brad
