Unfortunately the Ignitor has died.
Does anyone reckognise what make & model it is (no writing on it to identify
Ralfie wrote:Looks like Lumenition.
Try this link
http://www.bccp.nl/techdocs/PMA50ins.pdf
Might be helpful otherwise try google.
Landy Rover wrote:Is the pulse generator in the dizzy the old magnetic type or shutter wheel-hall or optical light?
If its magnetic (generates an ac voltage) you could use a horse shoe module out of early Mitsis or Mazdas, the two inner pins go to the generator and the outter larger ones coil positive and negative
gimmemud wrote:An electronics place might be able to fix it for you? Like somewhere that fixes ecu's
MNC wrote:If it helps this is a photo I got of the internals...
Thats a sealed unit. Need pic of the dizzy internals to identify what it might be.
If you have a good local Auto sparky he might be able to sorce a direct replacement, worth a go...
Landy Rover wrote:Thats a sealed unit. Need pic of the dizzy internals to identify what it might be.
Sadam_Husain wrote:might be easier and less mucking around to shove a standard points dizzy back in there Matt?
