I have a 98 discovery, it has cats and twin O2 sensors (pre and post cat)
i recently picked up a nex exhaust system - de cat,
it only has fittings for one set of Os sensors (pre -cat).
what should i do with this? just run one sensor pre-cat, or make up a fitting for the 2nd one too?
exhuast question
Re: exhuast question
i would get a hole drilled and a matching threaded nut welded on for the second sensor to screw into.
hmm. thats what I was thinkings.
quite often a sensor in a cat is only temp sensor??
DIRTY OLD HILUX
022 519 7700
022 519 7700
In my 1996 discovery engine loom, only the pre-cat 02 sensors connect to the EFI computer.
The other sensors (might just be temp) went to a seperate computer LR made just for the cat converters (along with various other pointless computers)
Since you don't have the cats anymore, I think you no longer require those post cat sensors aswell.
Pete
Pete
