lsd
poss682
lsd
Post by poss682 »
i am wanting an lsd for my non lsd 4.3 dose anyone have one its for my 87 surf or any alternatives for an lsd cheers 8)
suzolla
Re: lsd
Post by suzolla »
Hi,
How about a Lockright much better traction than an LSD.
See link http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=64&t=19572
Tim
poss682
Re: lsd
Post by poss682 »
thay wear out tires realy quickly would rather an lsd 8)
gimmemud
Re: lsd
Post by gimmemud »
poss682 wrote:thay wear out tires realy quickly would rather an lsd 8)
How do you figure that? They unlock automatically so on the road there should not be any excess wear on the tyres. Toyota lsd's are not known for quality, they may last a couple of trips but after that you'll need to tighten them again. Would go the lockright, you'll struggle to get it any cheaper than suzolla
J_Dub
Re: lsd
Post by J_Dub »
x2, wont find them cheaper, you will pay up to $400 for an l.s.d anyways
Petemcc
Re: lsd
Post by Petemcc »
X3 can't go past a locker! Best mod you will do...
Crash bandicoot
Re: lsd
Post by Crash bandicoot »
go find the diff head out of a 1990 SSR limited V6 surf. factory locker.
but hard on tires.
LOLYF
Re: lsd
Post by LOLYF »
Crash bandicoot wrote:go find the diff head out of a 1990 SSR limited V6 surf. factory locker.
but hard on tires.
:lol: :lol: where did you get that info from? surfs don't have factory locker, only f@#fed lsd,s
(Some overseas models did have factory electric locker but they are rarer than hens teeth and they don't wear out tyres because they are selectable)
Crash bandicoot
Re: lsd
I have a very good mate who has immigrated from south africa, and had a SSR-X "raider" over there (which is just a IFS hilux equivalent) but what the SSRX Raider has over the normal models is a factory locker, which is vacuum powered. Remember - sth Africa makes their own Toyota's (they do import some) but a great many Toyo's are made their and exported around the globe...
:mrgreen:
you can buy them too.
http://www.justdifferentials.com/index. ... ts_id=2947
note the bit that says "1988-1995 Toyota 4Runner with 3.0 V6"
which is our hilux surf ssrx
LOLYF
Re: lsd
Post by LOLYF »
:mrgreen:
That website is for a ring and pinion, not a locker.
Also your quote is incorrect, the factory locker (not available here) are electric. not vacuum
Also the "1988-1995 Toyota 4Runner with 3.0 V6" is referring to the american market vehicle.
I stand by my original post, you can't just " go find the diff head out of a 1990 SSR limited V6 surf. factory locker. " as the surfs we have a jap imports and don't have the factory locker.
tallsam66
Re: lsd
Post by tallsam66 »
My auto locker is awesome ..... by far the best mod if done to my hilux .... ive not noticed any increased wear with tyres
NJV6
Re: lsd
Post by NJV6 »
:mrgreen:
Yes but everything has factory lockers over there, Mazda Bounty's, Bt50's, Ford Rangers, Isuzu Rodeo etc, most of the utes are only 2WD but they still have factory lockers!!!
