Factory Rear Electric diff lock
Posted: Sat Feb 19, 2011 1:03 pm
by Ginzu8
Hey guys. last week my rear electric diff lock wont engage at all while i was at the local club run. the red light just keep flashing on the dash. when i got home and wash the mud off the car i decide to try it again and it worked both engaging and disengaging..
This weekend I decide to try it again and this time it took a bit longer to engage but then now it wont disengage at all. now i get a solid red light flashing. tried switching the switch to on and off couple of times and tried trying to drive in zigzag to see if its due to loaded pressure..
Anyone have any ideas what i can do or check ?? the 2x 30A fuses looks pretty good so its not that.
Any help would be great
Thanks
Re: Factory Rear Electric diff lock
Posted: Sat Feb 19, 2011 1:59 pm
by Filthy4x4
Hey dude,
Im not entirely sure if this will help you at all but my 4wd did the same thing wasnt engaging just kept flashing the light at me and beeping.
Turned out the plug needed a clean and the clip to hold it on had snapped off so it had come loose but was connected enough to make a beep and turn the light on.
Posted: Sat Feb 19, 2011 3:17 pm
by Ginzu8
Thx which end of the plug are you talking about? Also does anyone know if there is a way to manually disengage the diff lock so at least i can drive it to the work shop.. Not too keen todrive it to the mechanics with the diff lock engaged..
Posted: Sat Feb 19, 2011 8:14 pm
by kbushnz
Hey yah...
Have a read thru this thread. It will tell you how it works.
If its a factory install.
It has some interlocks which wont let it operate.
1 Going faster than 5 kms hour.
2 When in 2WD
3 Hi Range I think.....Cant remember.
You can override it..By putting power on the appropriate pins. But its easy on the bench... Hard in the truck.
I would suggest checking plugs.
And cycling it.
But you will have to have it in 4wd Low range.
Its a spring loaded splined gear which slides in to lock.
The electric motor powers it in or out by pushing against the spring.
The motor runs and when it compresses the spring stops the motor. Same for the other way.
Have fun
Calvin
Posted: Sat Feb 19, 2011 8:34 pm
by Ginzu8
hey Kbushnz, it is a factory installed like your one. right now iam getting a solid red light and i am pretty sure the diff lock is engaged. HOw the hell do i undo the plugs i managed to smack my shoulder on to the truck while trying to get hte plug off.. grrrr..
So the factory diff lock doesnt work with 4wd hi range? I am pretty sure i have it engaged in the past with 4wd hi range when i was off roading..
Also i think u forgot to add the link for me to read.. .
Posted: Sat Feb 19, 2011 8:35 pm
by Ginzu8
Do u know where the electric motor is as i got a feeling the motor might be dead as i had my wife turn the diff lock switch while i was under the car with my ear near the rear diff and heard nothing.
Posted: Sat Feb 19, 2011 9:30 pm
by mayday
its just to the drivers side of the diff head, where the driveshaft meets the diff.. they are very prone to water and mud, might need removing and cleaning
Posted: Sat Feb 19, 2011 9:36 pm
by Ginzu8
is it where the 2 plugs goes into ?? cause it if its i will try and take it out tmr to have a clean. anyone can give me tips on how to get the plugs off with out damaging it ..
Posted: Sat Feb 19, 2011 9:39 pm
by mudmike
If you want to unlock manually, pull the motor off, 4 nuts I think. then slide the toothed bar you can see away from the diff head. you may need to jack both wheels off the ground to unlock.
And I would check all the plugs starting at the diff and working back. All the plugs have clips on the side, if you don't push the clip you will struggle to pull them apart.
Good luck
Posted: Sat Feb 19, 2011 10:10 pm
by Ginzu8
is it the 4 little bolts that is facing the front of the truck??
Posted: Sun Feb 20, 2011 7:58 am
by mudmike
yes they are the ones around the electric motor, two on the bottom and two above I think. then it pulls off forward.
Posted: Sun Feb 20, 2011 4:55 pm
by Jungle
How did you get on? Another way to get it disengaged is to pull the top cover off the elctric motor. Then wind the motor manually.
Just make sure you keep down ward pressure on the motor so it doesn't just wind itself up out of the hole. I reckon have both wheels off the ground for this too.
Another option would be to just drive it and hope you don't have to squeel around too many round abouts.
Jungle
Posted: Sun Feb 20, 2011 6:36 pm
by Ginzu8
I have pretty much given up and have the truck tow to the mechanics.. I did my shoulder yesterday after going under the truck.. I tried undoing the plug but still no joy and gave up this morning.
Posted: Sun Feb 20, 2011 7:23 pm
by IcedJohnno
You wont need to get it towed to a garage.
You can drive it on tarseal and it wont damage the axle. Yes it will chirp trhe tyres going around tight corners and the steering may seem a little heavier, but that is all.
I had to fix mine at one point. Brushes had got gunged up in the wee electric motor. Took about 1/2 an hour.
I had driven it around town for about a week before this.
Posted: Sun Feb 20, 2011 8:55 pm
by Ginzu8
Oh real. I was told its not good for the diff with the locker engaged as when u turning the corner on tarseal that it would put too much pressure on the diff itself. anyway the towing tuck was free since i have break down mechanical insurance..
Hopefully by tmr i will know whats wrong and that its a cheap fix.
Posted: Thu Feb 24, 2011 10:32 am
by Ginzu8
Just like to update of my diff problem . Truck ended up in an auto sparky. its all fixed now, when i test it the other day it took a metre for the diff lock to engage and when i flick it off it goes off almost instantly which is awesome. Now i am not looknig forward to the bill. thanks for all the help guys..
