Snorkel flexible tubing
Mattman
Post by Mattman »
I have just about finished fitment of an Airflow snorkel and am not really a fan of the flexible tubing they have used.
Does anyone have any recommendations on anything suitable? Links to anything?
Matt.
Re: Snorkel flexible tubing
Aircon place in petone near the new roundabout/overpass, flexi pipe ... how much do you need? have got a wee bit left
Crash bandicoot
Post by Crash bandicoot »
ewww. :? go to your local muffler exhaust shop and ask for either aluminium or stainless flexi pipe.
looks like this Image
Drurban
Post by Drurban »
If you have a Blackwoods Paykels near you they sell flexi wire reinforced tube and alot of other Engineering goodies that could come in handy hose clamps etc.
Cheers.
Mattman
Post by Mattman »
Thanks guys. THey have supplied that black tubing which is wire wound but I wonder about the durability of it.
It will be going through the inner guard hole and I don't want it to wear down and puncture. Due to the layout of the inner guard it's impossible to protect it.
Might check out the flexible exhaust tubing.
Matt.
aroma
Post by aroma »
I put a piece of exhaust tube thru the inner guard to protect the pipe work
that exhaust flexy doesnt like sharp bends :shock:
Fakey
Post by Fakey »
Id seriously doubt that stainless flexi would be completely waterproof, it doesnt last that long on trucks in the exhaust system
Didn't barbie drive a jeep??
sibainmud
Post by sibainmud »
Non-toxic spiral-flex or marine water hose used for suction.
That's what I used cause it was just lying around the workshop.
Excuse the dust on filter (summer time at woodhill :roll: :roll: )
ZUKPWR
Post by ZUKPWR »
I used 65mm downpipe sections and flexible pipe that you put in gardens for drainage the stuff that's ribbed for extra pleasure :)
Mattman
Post by Mattman »
I ended up getting some black silicon joiners and sime 3in exhaust tube.
Matt.
flyingbrick
Post by flyingbrick »
Crash bandicoot wrote:ewww. :? go to your local muffler exhaust shop and ask for either aluminium or stainless flexi pipe.
could make a whole snorkel in one piece from intake to tophat with this :lol: :lol:
rangimotors
Post by rangimotors »
sibainmud wrote:Non-toxic spiral-flex or marine water hose used for suction.
I can only assume that you usually have an airbox or plan to in the near future :lol:
sibainmud
Post by sibainmud »
Yup, on the drawing board now. When I get this 3 inch to work, I'll use the same tube just bigger direct to the turbo and pod the top instead of the top hat.
rangimotors
for my last one i had pretty limited room for an airbox and ended up running a pod filter in a round encloser 3 inch in and 3 inch out. Did the trick, bought it off trademe advertised as a cold air box for a honda or something else funny
wjw
Post by wjw »
Mattman wrote:Thanks guys. THey have supplied that black tubing which is wire wound but I wonder about the durability of it.
Matt.
The hole in the guard should have had some rubber edging applied to it, to stop it chaffing
Who knew Prados could fly?
Return to “Tool Shed”
