i am currently halfway thru my 2.8 engine build, whats holding me up at the moment is the bore liners.
Does anyone have a bore liner removal tool i could borow or have any tips or advice to removing them, they are a nightmare.
thanks
bore liner remover
- mud_slinger
bore liner remover
needs more curry
0272593533
0272593533
Re: bore liner remover
Are they wet or dry? Forgive me as not a Mitzi expert.
When I have done marine engines, we heat the block gradually with oxy acetylene torch and spray cooling can into liner and then turn upside down and hit with big hammer and big drift on the bottom of liner. Had one once that wouldn't move because it had been saltwater cooled, used a mini angle grinder with cut off disc and carefully ground a line down complete liner until it cracked, but this was very scarey.
Otherwise, using custom made disc (round-tuit) on the bottom and a large tube on the top with a bridging plate and some threaded rod and nuts, but now i use a hollow jack on the porta-power in the same method.
Worst case send it to a engine reconditioner to have removed
Best of luck.
Best of luck.
- mud_slinger
Id take it to a local reconditioners an get them to press them out an press the new ones in
Didn't barbie drive a jeep??
