1991 Toyota Hilux 4wd
Brand new wof and reg and diesel kms
33x12.5 Mud stars Good tread on 15x8 white spokes
White spoke spare and 33
50mm body lift and 50mm suspension lift using brand new springs, New front shocks
TJM Winch bar (no winch)
3L turbo with intercooler, Set up from a 2LTE, Boost gauge, exhaust temp gauge and turbo timer
New clutch about 3 months ago
LSD diffs front and rear 4:3, New wheel bearing front and rear, New seals in front hubs
Tow hooks front and rear
Air flow Snorkel
Roll bar with torno cover to fit around bars
Bucket seats and centre from a ln130 surf
SR5 dash from hilux with oil press and volts gauge
Rubber flares, 20% tints , Brand new head lights, Sony explode 50X4 cd player with aux out and 4" JVC speaker in dash
This truck has had very little use in the last year and half due to having a company vehicle
Engine has had a compression test and leak down test done and came back good. Have compression test results
As is Where is
1991 toyota hilux double cab
Re: 1991 toyota hilux double cab
Hi mate, how many kms, how much you after and where are you?
