Can someone please help,I've just done 30mm lift on the rear when I raise the front will go bout 40mm (this is the question)will I need to flip a ball joint for 40mm lift.If yes please tell me where is the ball joint.As question shows I'm not that mechanically minded and still learning. So any help would be great.
thanks
front suspenion lift
- mud_slinger
Re: front suspenion lift
yes flip the ball joint,will give you bit of flex and also at wheel alignment time will get more adjustment out of it. its the ball joint on the top arm.
needs more curry
0272593533
0272593533
thanks 4 your help done 40mm lift went well so thanks again
Hi fatcat,
I would reccomend going to the ClubIsuzu site as it has helped me with so many of the Issues on my truck, this site has a good bunch of people.
So if you have any other questions go to that site first, as they might have the answer.
Cheers.
Cheers.
- mud_slinger
