Polyester Yacht Braid
Turaco
Newbie
Newbie
Post by Turaco »
Any one with experience in using Polyester Yacht Braid in recovery situations: non-stretchy, stronger than manilla, cheaper than dyneema, runs though blocks.
H2OLOVA
Post by H2OLOVA »
as long as you can find out its breaking strength you should be able to use it. whats the cost of it compared to the "proper" stuff?
albundy
Rolly Polly
Post by albundy »
Seen some cowboys back in Oz try using this. All I can say is lucky they weren't too close, would have lost their heads. If they were able to take the forces that recoveries induce then we all would be using it.
Al
H2OLOVA
Post by H2OLOVA »
sounds like you should get the proper stuff then.
worthog
Post by worthog »
The omly proper stuff is PLASMA - ARB are the agents, Grant Guy in Wellington 472-2020
All the other products are copies of Plasma
H2OLOVA
Post by H2OLOVA »
I presume you want to use this as a winch rope?
SupraLux
Complete Bastard
Post by SupraLux »
worthog wrote:The omly proper stuff is PLASMA - ARB are the agents, Grant Guy in Wellington 472-2020
Thats not to say Plasma is the only good stuff out there... there are plenty of good quality nylon winch ropes available... shop around.
Steve
worthog
Post by worthog »
Steve, what would u reccomend for a winch rope
SupraLux
Complete Bastard
Post by SupraLux »
Plasma :P
rokhound
Post by rokhound »
You still have to be carefull with some electric winches as the drum acts as a heat sink for the motor. Wire rope doesn't loose its integrety with heat build up (unlike some other materials). High mount electrics, hydraulics and PTO units should be okay, but check first.
tristanp
Post by tristanp »
truth be known, dyneema or spectra is the real deal
plasma is just a brand
albundy, the rope you saw was probally just nylon rope
albundy
Rolly Polly
Post by albundy »
Nah, it was definitely yatch rope as I have sailed alot when I was younger.
Al
tristanp
Post by tristanp »
ive been reading up over at http://www.samsonrope.com/
yeah there looks to be some with up to 15% stretch so theres gonna be some springback .
i bought some recently rated at 170t break and it has 0% stretch
