GQ factory diff locker won't disengage
Posted: Sun Mar 06, 2011 9:30 am
by Swamped
ok so I may not be able to drive the search option. But my rear locker won't disengage basically. at the moment just after a quick fix to drive home. Is there a vac line or something I can pull off to make it driveable? Making a horrendous clunking when reversing around a corner at the moment. Any long term fixes will be appreciated but getting it home in one piece is my current concern
Used the locker yesterday once, disengaged fine, dash light out. Today just re engages on its own wtf
Re: GQ factory diff locker won't disengage
Posted: Sun Mar 06, 2011 10:21 am
by coxsy
pull the vaccum hoses swap them around diff end or firewall end should disengauge
Posted: Sun Mar 06, 2011 1:50 pm
by DaveM
As coxsy said, swap hoses on the solenoids. These are a common problem, but you can buy replacements (aftermarket) which are reliable and engage/disengage a lot quicker.
Posted: Sun Mar 06, 2011 2:49 pm
by Swamped
DO they just get hung up every now and then? Its usually quite fast and only once a year ago it had an issue but this is new. All good though thanks.
With them reversed does the diff disengage when switch is set to on?
Do they rely on vac to engage or disengage with a return spring or similar or have vac for both?
Posted: Sun Mar 06, 2011 3:37 pm
by coxsy
well worked when i pumb mine the wrong way on the valve,
mac valve number 45A-AC-1-DDBA-1BA was $96 first time now
$20 odd more nissan wanted $475 + gst
Posted: Sun Mar 06, 2011 3:59 pm
by DaveM
Been a while since I've had one, but from memory, one solenoid locked, one unlocked, as in, the actuator is push/push, so one pushes closed, other pushes other way to open.
If one solenoid is not working, it will either fail to lock or unlock, so can't be reversed by the switch.
Could be wrong though
Posted: Sun Mar 06, 2011 5:10 pm
by Swamped
Riiiiight
It kinda comes across that if I swap the hoses around it will sort it. This correct or nah? Don't wana drive it home locked is all.
Its not been worked on so the hoses weren't reconnected the wrong way round. Just looking for a trick to disengage it.
Posted: Sun Mar 06, 2011 5:37 pm
by DaveM
Yep, swap the hoses over, should disengage it
