mu exhaust system
Posted: Sun Mar 06, 2011 9:03 pm
by fatcat
hi guys me again,removing rear muffler cause it so bloody big and keeps getting hooked up.Theres a gizmo half way along exhaust what is it and do i need it , someone said its an oxygen sensor is this right and to just remove it but unsure. So any help on this matter would be great
Re: mu exhaust system
Posted: Sun Mar 06, 2011 9:06 pm
by Drurban
Hi fatcat,
I have just done my exhaust on my truck to a 2.5 inch from the Turbo, I had an exhaust brake just after the flexy which is ok to remove, this is only needed in very cold conditions.
Is it a big square flange thing with a cable comming of it to and other unit
Ruben
Posted: Sun Mar 06, 2011 9:17 pm
by fatcat
its bolted between two joins with a like butterfly valve in the middle with cable running to little black box on drivers side . Sorry thats bout the best i can do
Posted: Sun Mar 06, 2011 9:21 pm
by Drurban
Yep that's it
Yeah you don't need this it is all good to remove this.
Posted: Sun Mar 06, 2011 9:24 pm
by Drurban
If you want a flange cut to do your exhaust just PM me and I can give you the file for it.
Ruben
Posted: Sun Mar 06, 2011 9:37 pm
by fatcat
Hey thanks you have been great help
Thanks again Paul
Posted: Sun Mar 06, 2011 9:42 pm
by Drurban
You are quit welcome, Iam glad to help.
Ruben
Posted: Mon Mar 07, 2011 6:58 pm
by mud_slinger
its not a exhaust brake the flap closes on cold mornings when you push the button on the dash, it allows the engine to heat up faster and run better while cold. i ditched my whole system for a strait thru 2.5 system and the dump pipe even has the waste gate plumbed in seperately
Posted: Mon Mar 07, 2011 10:01 pm
by Drurban
mud_slinger wrote:its not a exhaust brake the flap closes on cold mornings when you push the button on the dash, it allows the engine to heat up faster and run better while cold. i ditched my whole system for a strait thru 2.5 system and the dump pipe even has the waste gate plumbed in seperately
Cool thanks mud_slinger,
I dont know why I keep referring to it as an Exhaust brake, it kinda looks like one.
I have also done the same to mine what you did, what an improvment
Posted: Tue Mar 08, 2011 10:33 am
by GotFlex
i put a 2.5" exhaust from turbo with one short coby, goes way better, sound good not tractor like though which is what i wanted.
just done intercooler and fuel and boost adjust, currently running 16-17psi
Posted: Tue Mar 08, 2011 11:31 am
by Drurban
GotFlex wrote:i put a 2.5" exhaust from turbo with one short coby, goes way better, sound good not tractor like though which is what i wanted.
Hey GotFlex,
I have not done the intercooler yet when do you need to add an intercooler?
I have not done anything with the fuel or boost, I have a boost of 14psi 2.5 from turbo and medium muffler.
Sorry for hyjacking this post
Ruben
Posted: Tue Mar 08, 2011 2:48 pm
by GotFlex
im not sure when you should add a cooler, i just wanted to be on the safe side.
