I can't seem to get the fuel and temp gauges to work as there is no power..
WTD..picture of your dash cluster from behind
Hi guys, I really need a picture of a 73-74-75 dashcluster from the back as I have taken off the resistor and i'm thinking that there needs to be a wire to power the rest of the instruments as only half are going..
and if you can place a tester on the 2 ends and check if there is power going to both ends..
anyways any help would be great.. cheers K
Re: WTD..picture of your dash cluster from behind
Not sure if this helps LJ71 diesel and petrol guages
yep thats exactly what I need BUT mine is the same but it had a resistor running wires from left side to right through the resistor.. and I'm thinking it powered up the other half.. I have changed out all the bulbs and my old cluster outter the 70 didn't have the resistor in it as I took it out.. ran beautifully.. but I can't remember how I did it..LOL
Thanks Jerry.. they are the same but I noticed 2 screws different to mine so I've screwed them in and now I have power to the temp sender feed.. BUT it's too late for me to start up the old girl as the wife will have me gutss for garters.. and no hanky panky for a month..
so fark that.. it'll have to wait..LOL
anything in that wiring diagram I sent ya?
Jerry wrote:anything in that wiring diagram I sent ya?
not really.. as it is hard to see when you blow it up and compared to what I have.. it's either the same or very similar..
