94 and 95 cherokee engine difference?
Posted: Thu Mar 10, 2011 8:35 pm
by sharktale
Hey all.
It might be a stupid Q but are the any differences between the 95 and a 94 cherokee motors?
I've blown the motor in my 94 cherokee and i'v sourced a replacement engine from a 95.
Re: 94 and 95 cherokee engine difference?
Posted: Thu Mar 10, 2011 8:50 pm
by xj
no
Posted: Sun Mar 13, 2011 12:52 pm
by sharktale
Ok thanks.
Does any one here know where to pick one up? the one a had lined up is no longer available :(
Posted: Sun Mar 13, 2011 1:52 pm
by yeti
what part of nz fella :wink:
Posted: Sun Mar 13, 2011 3:40 pm
by sharktale
oh yea sorry haha, auckland north shore but any part of Auckland is sweet. Willing to drive out of Auck for a deal as well.
Posted: Sun Apr 03, 2011 6:42 pm
by coop
Did ya end up getting one? I have one sitting down in Cambridge you can have for a box of piss or two. It has done 310,000k when I parked her up a couple of years ago. You will need to bring an engine hoist down with ya, the rest of the Jeep is stripped so wouldn't take long to pull, I'll be happy to give you a hand if you need.
Ohh and how did you manage to blow one up, these things are pretty much bullet proof...
Posted: Sun Apr 24, 2011 10:14 pm
by sharktale
Hey sorry guys i forgot my log in password haha.
Umm well i'v got the new engine fitted and she sounds good! Im fronted with a new problem and that'll be the power steering pump. I got a second hand one couried from some wreckers place down the Waikato and that one turned up with Fecked bearings and a wobbly wheel so i'll be ring them first thing Tue, really dissappointing really, because i had planned a day out at woodhill and Muriwai!
"coop" i got a bit adventures in the puddles and tried a slightly deeper one :D bent ......no snapped a conrod ......ooooops haha
Any one selling a straight power steering pump? would like urgent.
0275 315 110
Posted: Sun Apr 24, 2011 10:16 pm
by sharktale
oh and any one have a diagram of the belt assembly/direction, i got 8 pulleys, i'v a fare idea of how it goes i just want to make sure.
Posted: Sun Apr 24, 2011 10:51 pm
by yeti
http://www.bestvalueautoparts.com/Repla ... uting.html
down the page a bit..should be a diagram under the hood
Posted: Wed Apr 27, 2011 9:24 pm
by sharktale
Well iv got yet another problem, After fitting the new power steering pump i took it for a ride up the road and i noticed the oil pressure, water temp and volt gauges weren't working and the "check engine" light was on, she coughed once and died all together. Upon restarting it cranked and cranked for 30 odd seconds (on and off) and finally started and ran fine and ideled nice when i got back but the gauges still weren't working.
I really want this thing going again big time i miss her hahah.
If any one can shead some light id really appreciate it!
Posted: Wed Apr 27, 2011 9:30 pm
by sharktale
yeti wrote:http://www.bestvalueautoparts.com/Replacement_Parts/JEEP/CHEROKEE/Illust_c_Belt_Routing.html
None of them have the 8 pulleys like mine.....weird, would having the belt on the wrong way around the alternator have some thing to do with the gauges playing up?
My main concern is which way it goes around the water pump.
Posted: Wed Apr 27, 2011 9:53 pm
by SP450andLE
sharktale wrote:Well iv got yet another problem, After fitting the new power steering pump i took it for a ride up the road and i noticed the oil pressure, water temp and volt gauges weren't working and the "check engine" light was on, she coughed once and died all together. Upon restarting it cranked and cranked for 30 odd seconds (on and off) and finally started and ran fine and ideled nice when i got back but the gauges still weren't working.
Did it smoke when it started up again?
If not, it could be a fueling problem...?
Posted: Wed Apr 27, 2011 11:07 pm
by sharktale
no i don't think it did smoke once it started.
Posted: Thu Apr 28, 2011 4:05 pm
by yeti
try this one
Posted: Thu Apr 28, 2011 10:19 pm
by sharktale
Thanks a heap for that "YETI" its now on the right way. :D
When is my damn luck gona change! now the power steering and belt route is sorted the aircon compressor decided to make an ugly bearing sound, does'nt make a difference wheather its on or off!!!!! AND the gauges are still playing up!!!!!
what to do, what to do!!!!!!!
Posted: Fri Apr 29, 2011 5:57 pm
by yeti
welcome to the world of jeeps,,,, best ya get the haynes jeep manual and have a read up....the ac pumps don't like mud and are down low,,I'm on my 2ND one ,,bout $80 2ND hand,,..did you do engine swap???? check out this site for parts,i have used it a few times , don't go to ripco and such..anyways good luck let us know how ya go....
LINK
http://www.offroadspecialties.co.nz/node/319
Posted: Tue May 03, 2011 8:27 pm
by sharktale
"Its a jeep thing" im still trying to come to terms with it haha.
Aircon and power steering sorted now
Took it out for a jam in the mudd last saturday, water temp still not working after new sensor, check engine light still on and it still cuts out periodically and is a bitch to get started again!
AND the calipers are stuck on........like seized, won't release don't no if its calipers, master cylinder or some thing else.
Might put a cover over it and put it on the back burner, really starting to piss me off!
Posted: Tue May 03, 2011 8:38 pm
by downunderxj
sharktale wrote: and it still cuts out periodically and is a bitch to get started again!
I had a problem where my jeep would just stop with no warning, and would take about 15 minutes to re-start. Turns out it was the Crank Shaft Position Sensor which is positioned near the top of the flywheel close to where the exhaust passes. They can get quite sensitive to heat over time, and won't let you start until they have cooled down. I bought one in from the US, a good sight cheaper than locally sourced, made all the difference and hasn't been a problem since.
I also ended up replacing the front O2 sensor, that also made a huge difference.
Do a search on http://www.naxja.org/forum for CPS, there is lots of information
sharktale wrote:AND the calipers are stuck on........like seized, won't release don't no if its calipers, master cylinder or some thing else.
The Jeep XJ has what they call phenolic brake pistons, a sort of plastic which once heated up are very reluctant to return to their original size. I ended up driving home one day from a trip in the Akatarawas with smoke pouring out the back from the brakes due to the same problem you describe. YOu can buy replacement calipers with steel pistons to replace.
Good time to get in some parts from the US with the current exchange rate.
Good luck
Ian
Posted: Tue May 03, 2011 8:42 pm
by yeti
good info Ian beat me to it lol..
that link i posted has the parts ,,,,
Posted: Mon May 30, 2011 7:58 pm
by sharktale
Well i finally got her out over the weekend and it ran pretty good, didn't over heat or cut out. Went for a run up the dunes at Muriwai Beach and found a little track on the way home. It idles a bit high when hot, thats the only thing left to sort out and she'll be 100% again.
Posted: Mon May 30, 2011 8:11 pm
by coop
Looking good there sharktale where in Auckland are you? Muriwai beach and Jeeps don't go down to well with me, my old XJ boiled the water out about 15km from Rimmer Rd access, so it was either leave her for the tide or drive her home hot, she was in the red for about 15 minutes under hard load in soft sand, she was as good as day one the following week towing 2 tonne lol.
My mate in his XJ and myself in a ZJ are going up Thompsons track this coming Monday if you are interested in coming along cheers.
Posted: Mon May 30, 2011 8:38 pm
by sharktale
Hot damn :shock:
We tryed getting to the bombing range? but the army guys had a fence up etc... we had a play around and took what i think was that Rimmer rd.....by the 60km sign i dunno haha.
Cheers for the invite ill see what happens, we're looking at going to woodhill on sunday if my truck survives i might tag along on monday.
Shes standard apart from the 31s but does ok i guess.
Posted: Mon May 30, 2011 8:45 pm
by sharktale
