WTD. HILUX 4.3 8" DIFF
I have broken a few teeth on my rear diff
so looking for a complete open center diff head or crown wheel and pinon at 4.3 ratio.
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
Re: WTD. HILUX 4.3 8" DIFF
how much do you want to spend?
under $200 would be nice
good luck with that one mate.
Phil
Phil
Are 4.3's rare or something now? When I was last buying diffs with my old surf 4.3's were really easy to find (about 3 years ago) and you could get an open head for about $150. Times must have changed! Maybe you should change to 4.5's haha I have a good 4.5 lsd for sale if you are interested.
i thought the same that 4.3 would be pretty common and there would be a few lying around.
Iv got a 4.3 all the up here you can have for a hundy if you get desperate. Dont know what shipping would cost. Will check its a 4.3 tonight...
I have a 4.3 ring and pinion (used) from my KZJ Prado.
Should be the same....
If you get desperate...
Price??? Say $50 plus any shipping costs. (as its only the ring and pinion)
But will double check if you are keen.
Shot into garage, ring 43 teeth, pinion 10 teeth.... 4.3 to 1
Calvin
Calvin
Cheers for the offers guys, looks like sambo from welly has one and is comeing down next week
Thanks Heaps
Simon
Thanks Heaps
Simon
PM nomis - he wrecks hilux and surfs and usually has diffs available
I'm also looking for a 4.3 , 4pinion 8" diff.
Going in the rear of a 130series surf.
Any thing considered
Cheers Chris
Cheers Chris
LR110 ..... LJ50 project
need 4.3 diff head in chch please PM if any one has one to sell
cheers Bob
cheers Bob
These diff heads are also very common in Hiace vans, so if you are looking you can also go that way.
