Suzuki diff ID
For all Suzuki related topics
unadunted
Suzuki diff ID
Post by unadunted »
Gidday, I have a pair of leaf sprung Suzuki axles, hub to hub with disc brake on the front. How can I know if they are 410, 413 or the wider Samurai? Thanx
suzookyman
Re: Suzuki diff ID
Post by suzookyman »
Hey, just got under mine to measure. Samurai front from inside of the disk protecter plate thingy is about 1190, on the sj413 its 1090.Cant measure my sj410,its up at our other place but the Samurai and Sj413 are bigger by heaps.Someone else may be able to help.Cant remember but arn't the 410 drum all round?
Al
UBZ
Re: Suzuki diff ID
Post by UBZ »
410 had a disc front as well.
Diff flanges and ratios is the other way to tell. If the marks from the drive shafts are still visible . Bolt spacing is different on all 3
410 uses a small spaced square flange.
413 slightly larger spacing with one curved side
Samurai uses the large spacing .
410 diffs are 4.11 ratio
413 diffs are 3.9 ratio
Sammy diffs are 3.6 ratio
lilpigzuk
Tiger Balm
Re: Suzuki diff ID
Post by lilpigzuk »
if you cant measure from backing plate to backing plate easily, then from outside of spring to outside (or outside to outside of the spring mount brackets on the housing) on a samurai is approx 770mm, on a SJ413/SJ410 it is approx 690mm. Thats narrows it down to one of those two easily. If its the 690mm then it will be out of SJ410 or SJ413 and identify by driveshaft pattern as per UBZs post
Cleary
Re: Suzuki diff ID
Post by Cleary »
UBZ wrote:410 diffs are 4.11 ratio
I think sammy diffs are 3.73 ratio (but still higher geared than 413).
Return to “Suzuki”
