surf heater
89lux
surf heater
Post by 89lux »
i have a ln61 with the aircon removed and the heater dosent work are they connected
vinceparts
Re: surf heater
Post by vinceparts »
by the heater not workign do u mean it doesnt blow air or it doesnt blow heat?
if it doesnt blow air then yes they are connected, when u move your heater switch from blue stripe to red stripe it opens up a small valve located on the firewall letting engine water travel through a small radiator in under your dash
if your getting air and no heat your heater valve maybe seized, if you dont know where this is get a mate to move the heater switch from red to blue and back and foward till you see the wire and lever move on the valve , usually on the passengers side of the firewall
89lux
Re: surf heater
Post by 89lux »
yea i mean no heat still blows air, thanks for the tip will look into it
89lux
Re: surf heater
Post by 89lux »
well the valve in the engine bay was stuck but after changing this its still not blowing hot air :( where do i look next its getting cold here and the windows are fogging up lol
Smurf
Re: surf heater
Post by Smurf »
take both heater hoses off the engine and use your garden hose to run water through one of them with the heater tap open. If you don't get water flowing through then your heater core or pipes to it are most likely blocked, Also check the metal pipes on your engine that you take the heater hoses off aren't blocked, they can fill with rust if your engine hasn't had anti freeze
89lux
Re: surf heater
Post by 89lux »
hi thanks for the tip when i chucked the hose down the pipe it pumped out a bit of sludge so hopefully it will work now guess ill find out this wkend
aLUX
Re: surf heater
Post by aLUX »
89lux wrote:hi thanks for the tip when i chucked the hose down the pipe it pumped out a bit of sludge so hopefully it will work now guess ill find out this wkend
Try and get as much of that 'sludge' out as poss and unblock it. Its just a mini radiator (heater core or radiator core) in there and can/will start to leak.
I had to replace one in my 01 hilux late last year, leaks radiator fluid all over passenger side foot well. wasn't hard to repair apart from the steap price for a new one that had to be imported from ausie.
If you do need to replace it, you have to take the dash out and keep disassembling it until you can get the heater ducting and eventually the heater box out (cable from red/blue heater switch leads to it) and pull it out from there. I had to take my WHOLE dash out - was a b1tch.
89lux
Re: surf heater
Post by 89lux »
well the hose trick worked a treat i now have a working heater :D :D :P thanks guys
