hi guys .
im usally in the mitzi area but need some help with the gfs truck
went through cooling system and found buggered thermostat replaced and run up.
then found viscous hub bearing had crapped its self also fan wax had leaked out and fan not spinning like it should.
of cause hub apart of pump so new pump $350 later. bolted all togeather tonight.
run up and heard strange noise and noticed fan was not spinning in sink. like in orbit
removed fan and run up again and shes is as smooth as and no noise.
so bent fan (would explain buggering old viscous hub)
any one got a good one?
or know of a place to get a new one?
fan for terrano td27 needed 1996
Re: fan for terrano td27 needed 1996
Can you measure the opposing bolt centres as there is a couple of variations.
I have 2 mint ones here, can sell one at a nominal fee
Simon.
Simon.
hi simon cheers for that.
measured it up and its 143 ish from center to center
would be great if you have one.
let me know
cheers garth
let me know
cheers garth
Both my spare ones here are 134mm ish
Sorry mate, you need the bigger one then.
Worth a try
Worth a try
