Rear Winch help....
Hilux Dan
Rear Winch help....
Post by Hilux Dan »
Hi there, just looking into the possibility of mounting my Tigerz11 winch under my rear tray somehow and running the line through to the front. I have seen a few set ups like this and I think it would suit the hilux as I need weight in the back and not the front.
My Hilux has IFS and i cant really see any clear way through for a rope. Has anyone done this with IFS ?? Would love to see some pics etc........or any suggestions would be cool.
Ive also noticed with alot of rear ounted winches, they seem to be mounted on an angle, not straight forward. Is there a reason for this ??
Thanks in advance....
Cheers Dan
SCA Floor Mats , Aftermarket Seat Covers , SCA Silicone Wiper Blades
SCA Tool Box , Repco Air Filter , more to come when budget allows......
sibainmud
Re: Rear Winch help....
Post by sibainmud »
Hey Dan,
It is as easy as running the rope through a tube affixed to a chassis rail.
Sounds like we need to have a design sesson 8)
Drurban
Post by Drurban »
You should see how much is in the way IFS stuff, it is not easy but Iam sure there will be a way.
Ruben
sibainmud
Post by sibainmud »
Drurban wrote:You should see how much is in the way IFS stuff, it is not easy but Iam sure there will be a way.
Ruben
No different to a IFS Terrano....sarus :lol:
Just have to be a little creative.
Hilux Dan
Post by Hilux Dan »
Yeah, Im sure there is a way, design session on !! Saw your truck outside Barts yesterday, will be in touch....
meatc
Post by meatc »
Mounting the winch on an angle is just about getting it square to the rope and centered. You need about 800-1000mm between the drum and the closest fairlead/tube then yeap find a path and away you go. Mine runs trough a tube most of the way and it has a few bends in it. (goes inside the cab too). Depending on how smooth you think the inside of the chassis rail is I've seen the rope run up there too.
rokhound
Post by rokhound »
Mine runs through the chassis rail, love to tell you how well it works, but it hasn't been tested yet
sibainmud
Post by sibainmud »
Hilux Dan wrote:Yeah, Im sure there is a way, design session on !! Saw your truck outside Barts yesterday, will be in touch....
Yeah, my mate works there now.
He got some cool equipment there too 8)
He's looking at breaking into the 4wd market rather than the "pocket rocket" modifications.
Drurban
Post by Drurban »
Hey Dan,
Maybe you can post a a photo from the back to the front taken from underneath the truck.
Cheers.
J_Dub
Post by J_Dub »
do a body lift, even just 25mm and that will create a clear straight line for ya
Hilux Dan
Post by Hilux Dan »
J_Dub wrote:do a body lift, even just 25mm and that will create a clear straight line for ya
Yeah, ive done a 50mm body lift, and a 50mm suspension lift, but there is no clear way through. Its all good till you get to the IFS stuff......cheers for the suggestion though..
meatc
Post by meatc »
Doesn't have to be straight, just use a tube or multiple fearleads. If you have a 50mm body lift you should be able to run a tube under the floor and if need be attached to the floor pan.
Hilux Dan
Post by Hilux Dan »
meatc wrote:Doesn't have to be straight, just use a tube or multiple fearleads. If you have a 50mm body lift you should be able to run a tube under the floor and if need be attached to the floor pan.
Yeah, under the floor pan area is all clear and plenty of room, its just once you get to the front. With all the IFS, Radiator, Steering Dampner etc there really isnt a line through.... I will try and take a pic that shows this.....
Smurf
Post by Smurf »
The cable doesn't need to come out the front in the center, follow the chassis rail all the way to the front and have the cable come out on one side of the radiator?
Hilux Dan
Post by Hilux Dan »
Smurf wrote:The cable doesn't need to come out the front in the center, follow the chassis rail all the way to the front and have the cable come out on one side of the radiator?
Yes I am aware of it not needing to be centre, but good on ya for checking. I will try and get a pic or 2 up tomorrow to show the front. Im no mechannic unfortunately so I cant really explain what parts are in the way. cheers.....
Drurban
Post by Drurban »
I can explain what is in the way no clear line past floor pan as Engine/transfer are quite low down also as mentioned IFS. I have seen this and there is little room on the sides but there maybe a possiblity to sneak a tube through somewhere. There diffienatly needs to be some investigateing on this.
dazza85
Post by dazza85 »
what about bending the tube to follow the chassis rail on the the engine side over the front axles ??
sibainmud
Post by sibainmud »
That's on the plan.
A bit of the right tube and a wee session with the pipe benders is all that is needed.
We missed having lunch today, but will have the design sesson before the weekend is out.
Input is all good 8)
suzolla
Post by suzolla »
Would have thought that you do not want too many bends due to the friction that will be generated particulaly with all the grit going through, more tension = more friction meaning a loss in pulling power.
Also need to be carefull that tube / pipe does not wear through, will cut the rope, presume you are looking at using stainless steel, will not wear as much.
Haven't had any actual experience, just trying to think of possible issues with using bent pipe.
If experience has found otherwise thats all good.
Tim
Mudhog
Post by Mudhog »
Hi Dan,
I see the plans are a changing on the winch position slowly :lol:
I'm going to be mounting Mudhogs winch in the rear too and have been looking into what the Winch Comp trucks have been doing. After talking to Warren at 4wdbits and looking at his truck and taking pic's I'm going to use 31mm Aluminium Extruded Round tube with a 5mm wall from Ullrich. The reason in using Alui tube this size is that it will disperse any heat from the rope, the wall thickness will keep it ridged enough once the bends are in and it's easy to work with.
Just the way I'm going. :D
sibainmud
Post by sibainmud »
Mudhog wrote:Hi Dan,
That's exactly what I was thinking too. Thick walled alloy :mrgreen:
Just a few subtle bends is all that will be needed.
Mudhog
Post by Mudhog »
So Dan, where have you decided to mount the winch :?:
Hilux Dan
Post by Hilux Dan »
Mudhog wrote:So Dan, where have you decided to mount the winch :?:
Well after thinking about it and going through scenarios im giong to stick with whacking it on the front like everyone else. Maybe in the future I can make the change.......
Thanks everyone for the suggestions though......
chevrolux
Post by chevrolux »
Did you see how rokhound did it? winch just behind/in the cab. Line ran to back through a removable block pulley. Welded a big chain link in to a hole cut in chassis rail to act as fairlead. pops out the front of the truck ready to use :) You probably dont need the removable block at the back (unless you want the option of winching backwards). But yea seems like a simple enough thing to do. Check out the mutt's build thread and you will see what i mean.
Hilux Dan
Post by Hilux Dan »
chevrolux wrote:Did you see how rokhound did it? winch just behind/in the cab. Line ran to back through a removable block pulley. Welded a big chain link in to a hole cut in chassis rail to act as fairlead. pops out the front of the truck ready to use :) You probably dont need the removable block at the back (unless you want the option of winching backwards). But yea seems like a simple enough thing to do. Check out the mutt's build thread and you will see what i mean.
cheers......will check it out. :D
Big
Post by Big »
Just change to plasma and use a plastic pipe..(Conduit- about 20-25mm) from any electrical store/ outlet.. run it any way you like as long as it's to the front.. clip to what ever you can and it won't wear through .. tried and proven on another winch truck that I know had a hammering.. I'll be doing the same when I get a cheapish electric winch for my setup.. real easy no hassle..
Only hassle is getting the plasma.. $$$ but in the long run is for the better and safer on you and the surrounding people..cheers
Return to “Tool Shed”
