wanted: argon bottle for mig
hi
not sure if this is the right place to put this thread,thourght id put it on ore as everyone seems to look after each other, im after a argon ownership bottle for my mig so i can run mix of argon and c02.
does any one have one they want to sell or have a contact of sumone that sells them im not real keen on paying $700 for one.
any help would be great im in christchurch but dont mind getting couier to pick stuff up
need to get bottle sorted so the mods can start
cheers boys
cheers boys
Re: wanted: argon bottle for mig
My bottle was brand new from http://www.weldplus.co.nz/ but the Dunedin branch. Think it was like $350 and there was a smaller bottle available too.
uwish wrote:hi
cheers boys
I got a co2 fire extinuisher bottle and got it converted cost about $150 including bottle. I am sure you can use the co2 bottle for argon.
GU patrol 35s ect.
yep just gotta be painted the rite colour. Same shop could do an old extinguisher converted for cheaper but retest is in say 2yrs instead of 5yrs with new.Something like that anyway.
when talking to southern gas in chch they said that depending what the bottle was originally certed for (a range of gases) will determine what the bottle can be filled with.
so painting it does not work and they (and boc) would not fill bottle
also said that alot of the bottles sold for c02 gases can not be filled with the mix
anyone eles heard this?
If you want argon co2 mix why dont you just hire/buy argo shield?
Didn't barbie drive a jeep??
not sure what you mean the gas or bottle?
i want to buy a bottle suitable for filling with argo sheild, i dont want to hire one because i may not use the full bottle all at once so have to pay for bottle sitting there for nothing, plus boc is a on year contract.
also im in my 20's so if i buy one now it will pay for itself with 3-4 years rental and i still have it at the end
I got mine from supergas, they fill and sometimes sell bottles, think they were $350 for a D size
thanks mike but is that bottle allowed to be filled with argosheild?
rental is monthly, the terms dont dictate you keep it for a year, and if you are worried about not finishing your bottle either pimp out your services and finish it or turn your gas flow up
DIRTY OLD HILUX
022 519 7700
022 519 7700
argo sheild is more costly than co2 and the mig is normaly made to suit on or the other gases
coxsy wrote:argo sheild is more costly than co2 and the mig is normaly made to suit on or the other gases
Personaly I would only use argon for tig. As said it costs more and you only get a slightly better looking weld. Some one correct me if I am wrong but you get better penetration with co2?
GU patrol 35s ect.
correct
i thought co2 was only better when you use flux cored wire? is that another ball game.
Personally.. argoshield rocks!! welds might not go as deep but nothing the volume knob cant fix. co2 is just so angry lol.
as for buying a bottle. Why pay 500 odd bucks when you rent one for 15 a fortnight and take the bottle back when you dont want it. If you are anything like me and just weld in the weekends working on your own junkers a bottle will last a couple months and I dont get anohter bottle until i reckon i will need to do some welding. plus you get the bonus of having an account at boc so if you havent got cash all your metal working supplies just go on the account lol. its great!!
edit: 15 a MONTH not fortnight
chevrolux wrote:i thought co2 was only better when you use flux cored wire? is that another ball game.
Not disagreeing with you chevrolux just giving my 2cents, you dont need any gas for flux cored. I fine that co2 works very well for me. $15 a month you would pay a small bottle off in a year
GU patrol 35s ect.
Old thread but relevant for me.
Have prices changed much? Looking to flick my little CO2 bottle and reg (I damaged the contents gauge and will replace it) off and get argoshield mix for my panel work. A drop in weld temp might help me not blow holes in thin steel (probably not though - settings seem too coarse - either too hot or not enough) and nice welds would be appreciated by the certifier I think.
Looking for about D size or slightly bigger in Chch and also a reg.
They do an "argoshield light"as well Heath. I have not used it but apparently has less CO2 and therefore less penetration than the normal argoshield mix. Stops you from blowing through as easy. I assume you are running a lighter wire for your panel work?
running .8mm at the moment (have some .6mm wire but havent changed over yet). Blew a nice hole through a side panel (low on the sill) last night which pissed me off. Now I have to fill it and get it looking nice - bastard!! I think there may be some bog used in this build.
Put the .6 in bro. Makes a big difference. I am forever chasing holes with the .8 but can actually get a bead going with the .6 (that's with normal argo shield). Also I think the theory goes that you should be able to use less heat and get less warping with th .6.
I'm hearing ya. Just lazy I guess. Another job to do...
Bloody gas ran out on Sunday. Dropepd it off on tuesday after work expecting to pick up yesterday (Wed) but got a call to say it was out of test and had to be checked before they would fill it. Sure, no worries send it out I figured, but now it seems it may not be back for the weekend so nothing will happen unless it comes back quickly. Never mind gives me time to find a new gauge for the regulator and swap the wire over to .6mm too.
Might hold off on the guage incase it fails and then I will go for argon light from weld worx or similar. Still might move it on anyway even if it passes. Not sure on CO2 yet...
