Al
Samurai playing up
suzookyman
Samurai playing up
Al
Re: Samurai playing up
Strip and clean the carby, staving will it being full of crap and it prob been ajusted up and up to sort it. Maybe, or theres a vacum hose witha hole in it.
suzookyman
Had vacume hose prob before and rev'd up 1500 at idle.Must be
carb adjustment, can't do that so it's off to the shop it goes
Al
Al
Get a can of engine start
With the engine running selectively spay it at a vacuum line , vsv Valves etc.
If their is a leak the engine should pick up in revs when you spray the right area.
Other things to check is the one way valve into the brake booster
That the acelerator cable isn't Jamed and not allowing proper idle or that the the egr valve is jammed open or vapor canister blocked.
Down load the FSM from [url]suzukiinfo.com[/url]
will give you all the tests for all the carb and vacuum components.most are easy to diagnosis
LR110 ..... LJ50 project
That sucks, hope it doesn't cost too much or it might be time to put that 1600 in
All good advice here, I've noticed my motorbikes often idle high when the fuel is running out, so it sounds like fuel starvation is probably causing all your problems. Not that hard to take the carb moderately apart and just clean everything out with some clean petrol. Good luck!
suzookyman
zukmeista wrote:That sucks, hope it doesn't cost too much or it might be time to put that 1600 in
Yeah, its going in after the winchcomp at easter
suzookyman
Great replies guys, I will have a look at it tonight.
cheers Al
cheers Al
suzookyman
Ok, took zook to a mates place (thanks Kev) and he showed me how to strip and clean a carb.Chucked it back in and its like a new machine! ,also discovered the previous owner has put a different carb on it as im sure Samurai''s arnt twin throat
.Glad i didn't have to take it to the shop $$ as its coming out next month to put the Vitara in ( anyone after a good nick g13b?)
Al
Al
