Samurai playing up
Posted: Thu Mar 31, 2011 6:39 pm
by suzookyman
:roll: Ok so the wife took the zook for a blast out in the country today and when she got up to 80kph she said it was farting and starving for fuel, so i went and got a new fuel filter ( had these sort of syptoms before and was a $5.00 fix ),I chucked the new filter in tonight and now it idles a 2500 WTF :roll: :evil: is going on? got me beat -Im no mechanic :(
Al
Re: Samurai playing up
Posted: Thu Mar 31, 2011 7:08 pm
by meatc
Strip and clean the carby, staving will it being full of crap and it prob been ajusted up and up to sort it. Maybe, or theres a vacum hose witha hole in it.
Posted: Thu Mar 31, 2011 7:54 pm
by suzookyman
Had vacume hose prob before and rev'd up 1500 at idle.Must be
carb adjustment, can't do that so it's off to the shop it goes :x
Al
Posted: Fri Apr 01, 2011 3:25 am
by UBZ
Get a can of engine start
With the engine running selectively spay it at a vacuum line , vsv Valves etc.
If their is a leak the engine should pick up in revs when you spray the right area.
Other things to check is the one way valve into the brake booster
That the acelerator cable isn't Jamed and not allowing proper idle or that the the egr valve is jammed open or vapor canister blocked.
Down load the FSM from [url]suzukiinfo.com[/url]
will give you all the tests for all the carb and vacuum components.most are easy to diagnosis
Posted: Fri Apr 01, 2011 8:58 am
by zukmeista
That sucks, hope it doesn't cost too much or it might be time to put that 1600 in :wink:
Posted: Fri Apr 01, 2011 9:35 am
by kernels
All good advice here, I've noticed my motorbikes often idle high when the fuel is running out, so it sounds like fuel starvation is probably causing all your problems. Not that hard to take the carb moderately apart and just clean everything out with some clean petrol. Good luck!
Posted: Fri Apr 01, 2011 11:18 am
by suzookyman
zukmeista wrote:That sucks, hope it doesn't cost too much or it might be time to put that 1600 in :wink:
Yeah, its going in after the winchcomp at easter 8) -havn't got time to do it before then :(
Posted: Fri Apr 01, 2011 11:19 am
by suzookyman
Great replies guys, I will have a look at it tonight.
cheers Al
Posted: Sun Apr 03, 2011 5:27 pm
by suzookyman
Ok, took zook to a mates place (thanks Kev) and he showed me how to strip and clean a carb.Chucked it back in and its like a new machine! ,also discovered the previous owner has put a different carb on it as im sure Samurai''s arnt twin throat 8) .Glad i didn't have to take it to the shop $$ as its coming out next month to put the Vitara in ( anyone after a good nick g13b?)
Al
