Heya was just wondering what it means when springs have titles like 50mm lift springs to 40kg.
Whats the 40kg mean?
Refernce is the 4wdbits website
gq springs
- crazyclark31
Re: gq springs
Pretty sure that will mean 40kg over your standard weight.
i.e. if you were smuggling 40kgs of Mexicans across the border in the front or back (you can have different ratings for both) of your truck, it would still be 50mm higher than the standard height rather than sagging below from the extra weight.
- crazyclark31
Re: gq springs
yeh thought that might be the case.
