ln106 gear box
- bigboar357
- Driver/Navigator
ln106 gear box
can any body tel me if u can put a surf gear box into a 94 ln106
Re: ln106 gear box
They will swap, but the floor will need a longer hole cut in it as the distace from the front of the bellhousing to the transfer lever is about 100mm more.If you have bench seat it will interfere with transfer lever.
I am just redoing a ln106 that has been attacked with a grinder to make a surf box fit.
Because I want to put bench seat back in I have gone to original box.
- bigboar357
- Driver/Navigator
Re: ln106 gear box
so a ln130 gear box will fit. anything els i will need to do
