chassis stands
chassis stands
went to check out repco and super cheap for a set of chassis stands high enough for a Hilux and they where both useless. Can anyone point me in the right direction to get some...
Re: chassis stands
did you try some 5t ones as they are nearly twice the length of the smaller ones, this is what i use in my 105 series with 35s on and it works grate.
Phil
Phil
Re: chassis stands
Repco have a good range but some stores you have to ask as not everything is on the shelf waiting for you. They will get them in which usually only takes a day.
They are more commonly referred to as axle stands and you will want at least 3 ton or larger. I have some 6 ton ones but you need to good jack to lift vehicle high enough to utilise the full height of those ones.
Re: chassis stands
Philip did you get yours from repco?
I asked the sales person in both shops and they didnt have a clue. Might try and ring tomorrow and see if i get someone in the know.
- ClassicCruiserSpares
- Sausage Shack
Re: chassis stands
If you asked for chassis stands they probably wouldnt know what your talking about, most people call them axle stands now.
- williamhamilton
Re: chassis stands
timmay556 wrote:went to check out repco and super cheap for a set of chassis stands high enough for a Hilux and they where both useless. Can anyone point me in the right direction to get some...
What part of the country are you in?
W
SP450andLE
Re: chassis stands
ClassicCruiserSpares wrote:If you asked for chassis stands they probably wouldnt know what your talking about, most people call them axle stands now.
Or jack stands
pruggerdore
Re: chassis stands
any where that sells "powerbuilt" brand tools, which is every where. will be able to get the powerbuilt 5or6 ton truck axle stands which go about 600mm high and have a wide base. tho the same ones used to be bigger 10 years ago when I got mine.. mate bought there big ones about 3 years and they were a bit smaller. Trade tool suppliers like "Total trade" "tradeZone" which I think are nationwide chains stock power built
Re: chassis stands
I got my 6 tons stands off trade me from TOPMAQ...are real high & sturdy....also have a big footprint so wont topple over easily
Re: chassis stands
Im in Taupo sorry mate.
I will check out that tard me guy.
Re: chassis stands
Na mate i got them from Barn saver i think that is what the place is called i can fined out if you like.
i think it cost me $175 for 2 stands and 1 3.5t jack.
i found then on trademe
Phil
Phil
timmay556 wrote:Philip did you get yours from repco?
Re: chassis stands
awesome, thanks guys
