TERRANO BULLBAR PROBLEM
For all Nissan related topics
tatnz
Post by tatnz »
So the other week i got a bullbar/winch bar for my terrano off trademe.
Today i went to put it on and what do you know none of the mounts line up and dont even look the same!
I have put some pix up for you all to have a look at let me know what you think.
bumper in front of the truck
old and new bumper
side on of the two bumpers
the old bumper and light bar with the new bullbar mounts
ok by the look of the preview the pix did not load?
i followed the step by step that DieselBoy put on the show us your nassin post. i most-likely did it RONG :roll: could some one please help :mrgreen:
this link will take you to a terrano with the same bumper
http://www.trademe.co.nz/Trade-Me-Motors/Cars/Nissan/auction-367588915.htm
Overkill
Re: TERRANO BULLBAR PROBLEM
Post by Overkill »
tatnz wrote:I have put some pix up for you all to have a look at let me know what you think.
You will have to use a site like photobucket.com to load pics from, you can't publish from your desktop....... :wink:
u13turbo
Post by u13turbo »
tatnz wrote:So the other week i got a bullbar/winch bar for my terrano off trademe.
[img]C:UsersUserDesktopPicturestruckDSC02118.jpg[/img]
[img]C:UsersUserDesktopPicturestruckDSC02119.jpg[/img]
old and new bumper
[img]C:UsersUserDesktopPicturestruckDSC02120.jpg[/img]
[img]C:UsersUserDesktopPicturestruckDSC02116.jpg[/img]
new bumper/old bumper/lower bullbar
[img]C:UsersUserDesktopPicturestruckDSC02117.jpg[/img]
new bumper/old bumper/lower bullbar mounts
Hey mate, i have very similar bullbars on my terrano, easy enough to fit, there is a mount that can come off the truck and off the bullbars, make sure you have them too pieces, try get your photos up properly aswel.
tatnz
Post by tatnz »
thanks overkill :mrgreen: :mrgreen:
kiwipete
Post by kiwipete »
Failing that, send them to me and I will fit them on my truck for you. :wink:
Ph 0212078472
tatnz
Post by tatnz »
i think i have solved this problem
1)cut the front bumper mount
2)then wield 5 or 10 mm plate to the cut mounts out of the front to the bumper where i will drill the bolt holes for the bumper.
3)then make a 2nd bracket from where the standed light holder/bullbar goes,out and up to meet the first bracket.
that would make it a 4 point mount all up what do you think.
if i put a plate in there for a winch will it be strong enough or rip to pieces?
tatnz
Post by tatnz »
hay kiwipete do you know how the lsd from a r200 into the front diff went is there
a step by step on here or is it get the die grinder out and make it fit :lol:
kiwipete
Post by kiwipete »
Your method is about the same as my proposed set up will be too, but I will not be using the old bumper irons though, rather making some 5mm ones and trying to extend them to the chassis rail. Some engineering will be required to mount the drivers side bracket as the steering unit is in the way but I'm sure it can be done.
I do not think the original bumper irons will be strong enough to stop any rotational forces of the bars as they are only 3mm steel, and the bolts are only 6 or 8mm diameter from memory.
Other input is welcomed though.
Ph 0212078472
kiwipete
Post by kiwipete »
tatnz wrote:hay kiwipete do you know how the lsd from a r200 into the front diff went is there
I have not heard yet, but a z300 one fits too with mods. I do not know what mods though.
You would not want it set up too tight as you will have no or little steering in loose or muddy conditions.
I recon a good tight LSD in the back is suffice IMHO.
Ph 0212078472
tatnz
Post by tatnz »
I found these on the net
