removing tie rod ends, terrano
Trying to get the tierods off the draglink, just to replace my draglink, I've fucked the little boots on the tierods with a splitter tool and the still havnt even split. Is there an easier way? bloody great cos its ended up costing me more, i'll need new tie rods....
Re: removing tie rod ends, terrano
from memory they are pressed in, did you remove the cir-clips (depends on model)?
most likley covered in dirt and grease
Crash bandicoot wrote:from memory they are pressed in, did you remove the cir-clips (depends on model)?
Cant see any circlips, iv got my tie rod splitter in there, hit it fricken hard with slegde hammer many times and it aint budging..... what a #### up, i kinda need to use it for work tomorrow and i dont think thats gonna happen now.
D21 btw, 1991
- mud_slinger
there are no circlips on the ball joints. keep perservering with it. you'll get there. prob rusted in place
needs more curry
0272593533
0272593533
mud_slinger wrote:there are no circlips on the ball joints. keep perservering with it. you'll get there. prob rusted in place
Got it done, boots on the tie rods are farked, will i need to buy new tie rods now? or will they last ages?
You should be able to buy the boots.
The boot is there to hold the grease in so would say you'll need new ones. Wouldn't have thought they'd be too expensive.
- mudlva
just a little thread hijack
can you just buy the rubber boots and if so from where??
cheers hijack over
cheers hijack over
That's what these bad-boys are for, popping tie rods and ball joints without rooting the boots or the nut threads.
Takes about 10 mins to change a tie-rod end
- mudlva
sibainmud wrote:That's what these bad-boys are for, popping tie rods and ball joints without rooting the boots or the nut threads.
Takes about 10 mins to change a tie-rod end![]()
nice where abouts do you get those from??
This is the newer version,
Same brand.
http://www.waihyd.co.nz/sykes-pickavant-ball-joint-seperator-xidp325041.html
http://www.waihyd.co.nz/sykes-pickavant-20mm-throat-balljoint-separator-xidp228493.html
Same brand.
mudlva wrote:just a little thread hijack![]()
cheers hijack over
I got some from a place in Epsom Rd here in Chch, but I cannot for the life of me remember the name of the place.
Ph 0212078472
Ph 0212078472
mudlva wrote:sibainmud wrote:That's what these bad-boys are for, popping tie rods and ball joints without rooting the boots or the nut threads.
http://www.trademe.co.nz/Browse/SearchResults.aspx?searchType=all&searchString=ball+joint+separator&type=Search&generalSearch_keypresses=11&generalSearch_suggested=20
Ph 0212078472
Ph 0212078472
