33s on a sj413?
For all Suzuki related topics
Mr Zuk
33s on a sj413?
Post by Mr Zuk »
I currenty have 31s but would easily fit 33s, anyone run 33s on there zuk with starded axels?
You Get That
Re: 33s on a sj413?
Post by You Get That »
I have seen it work good not much stress on the axles if you play in mud not rock.
If you are going to do it look for some skinny 33s like 9.5s or 10.5s
Addicted to suzukis....
lilpigzuk
Tiger Balm
Re: 33s on a sj413?
Post by lilpigzuk »
What sort of transfer case gears do you have? I would imagine you would have to go up to 5.14 rockhopper gears to get your gearing back
like this
http://www.lowrangeoffroad.com/index.ph ... arset.html
Heath
Re: 33s on a sj413?
Post by Heath »
I'd imagine you will become quite efficient in changing CV's and perhaps rear axles too. As a test of the twist paint a straight line along the axle and after a few months pull it and see if it spirals around the axle. If it does they are being loaded up and will probably fail at some stage.
I'd imagine a set of lux axles combined with high ratio diffs (low geared) and a set of rockhopper/lobster gears in the t case and skinny tyres (maybe alloy wheels - to keep the rotating mass/ weight down). Maybe the tcase could be swapped for a 410 tcase for a simple gear change.
Will be good though...
UBZ
Re: 33s on a sj413?
Post by UBZ »
modded samurai housings
chromoly axles / cv's
diff gears
transfer gears
power steering
then chop where it rubs.
then
vented vitara front brakes
engine mounts
gearbox mount
transfer case mounts
and anti wrap bar.
= farken awesome ground clearance
redz driver
Re: 33s on a sj413?
Post by redz driver »
haha Yea been there tried that with my 413 the bitch become lazy and kept laying its its side for a bloody nap
Real men drive swb leaf spring trucks
Return to “Suzuki”
