Diesel motor using to much fuel
Posted: Wed Apr 20, 2011 8:33 pm
by u13turbo
Hey guys, my td27t terrano uses about 75litres for 450kms, i know for a fact other terranos get alot more, up to 700kms.
I have done small checks like checking the intake is clear, and exhaust etc, I think it must be injectors or injector pump, Where can i get them checked? is it expensive?
Re: Diesel motor using to much fuel
Posted: Wed Apr 20, 2011 8:44 pm
by mud_slinger
have you wound the fuel screw down?
Posted: Wed Apr 20, 2011 8:48 pm
by u13turbo
mud_slinger wrote:have you wound the fuel screw down?
Yep done it enough to get rid of the smoke, but it must mean somethings buggered cos it should be fine at its original setting? it made bugger all difference to the ks from a tank too.
Posted: Wed Apr 20, 2011 9:00 pm
by mud_slinger
sus a 2nd hand pump and give that a try and get ya injectors cleaned and flow tested.
oh you dont have a diesel leak do you by any chance?
Posted: Wed Apr 20, 2011 9:45 pm
by u13turbo
mud_slinger wrote:sus a 2nd hand pump and give that a try and get ya injectors cleaned and flow tested.
Na i cant see any leaking. I might go up to Gavins and see what he reckons, he has some pumps there, might help me out.
Posted: Wed Apr 20, 2011 9:54 pm
by curly12
Check you aircleaner and take you farken foot off the gas. Diesels need fuel and air to burn right. Check any restrictions
Posted: Wed Apr 20, 2011 10:03 pm
by u13turbo
curly12 wrote:Check you aircleaner and take you farken foot off the gas. Diesels need fuel and air to burn right. Check any restrictions
As i said i did check the air intake(including fitler, was replaced bout 2months ago) and it was all fine. Also i tried a tank with a light foot and it made bugger all difference.
Posted: Wed Apr 20, 2011 10:29 pm
by rangimotors
you driving around town? these other trucks getting 700 sounds pretty huge. There is always a huge difference between someone driving around town and then someone in an identicle truck that does non stop open road driving.
Posted: Thu Apr 21, 2011 12:13 am
by Nivapulledout
If it is not black smoking then it is not dumping it into the cylinders.no need to check your injectors and pump.
I would possibly say a fuel leak or someone is nicking fuel out of your tank.
Posted: Thu Apr 21, 2011 7:26 pm
by u13turbo
rangimotors wrote:you driving around town? these other trucks getting 700 sounds pretty huge. There is always a huge difference between someone driving around town and then someone in an identicle truck that does non stop open road driving.
Its abit of both, everytime i start it i drive atleast 25km open road.
Posted: Thu Apr 21, 2011 7:27 pm
by u13turbo
Nivapulledout wrote:If it is not black smoking then it is not dumping it into the cylinders.no need to check your injectors and pump.
Ok, It just seems that 16.6l per hundred ks seems really high...
Posted: Thu Apr 21, 2011 11:58 pm
by Nivapulledout
What I am trying to say is that if the injectors or pump were letting in more fuel and you are not black smoking it means that there is a complete burn going on so the If there was increased fueling it would give you more power. Which normally means you take your foot off a bit (back to normal fuelling levels) and will use the same amount of fuel as normal. So if no black smoke or power increase then it is not the pump or injectors. Injectors tend to wear and start loosing their ability to atomize the fuel properly or dribble, both cause black smoke!!
16l per 100 km is alot compared to my fathers ( he fills his tank at around 650kms cause his fuel gauge is broken and he never runs out!! he normally loaded up as well)
I would definitely be looking for either a fuel leak on the Fuel return line somewhere, or around your tank. It may be worth putting an anti siphon spring into your filling hose just to make sure no one is nicking the fuel.
Posted: Fri Apr 22, 2011 9:27 am
by u13turbo
Nivapulledout wrote:What I am trying to say is that if the injectors or pump were letting in more fuel and you are not black smoking it means that there is a complete burn going on so the If there was increased fueling it would give you more power. Which normally means you take your foot off a bit (back to normal fuelling levels) and will use the same amount of fuel as normal. So if no black smoke or power increase then it is not the pump or injectors. Injectors tend to wear and start loosing their ability to atomize the fuel properly or dribble, both cause black smoke!!
Ok thanks for that, It used to blow quite alot of black smoke until i turned the pump down, so there was something wrong.
Also i really dont think its being siphoned, i live down a really quite street and the gauge goes down evenly.
Posted: Fri Apr 22, 2011 9:59 am
by tweake
not sure if that model has egr but it would pay to check if has it and if its been blocked off. egr valves are known for sticking open which increases fuel consumption a fair bit.
Posted: Fri Apr 22, 2011 10:08 am
by u13turbo
tweake wrote:not sure if that model has egr but it would pay to check if has it and if its been blocked off. egr valves are known for sticking open which increases fuel consumption a fair bit.
Ahhh yes it does have EGR, shit i was meant to take that out awhile ago, looks abit of a mish tho cos it attaches under the manifolds...
Posted: Fri Apr 22, 2011 9:17 pm
by mud_slinger
just take ya egr out mate its overrated
Posted: Sat Apr 23, 2011 8:24 am
by u13turbo
mud_slinger wrote:just take ya egr out mate its overrated
Yeah i definitly want to, just gotta find the time to do it, and borrow someones welder, With the little actuator on intake sid, and i just block it past that?
Posted: Sat Apr 23, 2011 9:55 am
by Pedro
you may be able to unbolt the egr and make a steel plate that fits between the egr block and mount, the steel plate blocks the egr and looks stock...
pedro
